2JZ swapped 2013 Scion FR-S at auction for 10k
okMK
Gti
https://carsandbids.com/auctions/3LapBXRY/2013-scion-fr-s
How crazy is this? The list of mods on this car go on for miles, and there is a ton of rice strapped to this thing... but there's also a 536 HP 2JZ under the hood. Videos of the auction show what looks to be nothing more than a teenager behind the wheel of this thing. Where the heck did the money for this come from, and why in the hell is he selling it? It's an interesting auction, but so many red flags.
The list of mods is absolutely crazy.
  • "2JZ" engine block
  • CP Carillo 9.5:1 pistons
  • Manley Performance connecting rods
  • ACL Race Series connecting rod and crankshaft bearings
  • "1JZ" cylinder head
  • Shimless bucket conversion kit
  • ARP Bolts L19 head studs
  • Gates timing belt
  • Fluidampr engine damper crank pulley
  • Titan Motorsports oil pump
  • "2JZ-GTE" water pump
  • Brian Crower Stage 3 camshafts, adjustable camshaft gears, springs, and retainers
  • Haltech Platinum Sport 2000 ECU
  • Haltech wideband controller kit
  • Custom-made engine wiring harness
  • Mishimoto radiator, intercooler, oil cooler, and sandwich plate
  • Modified Godspeed intake manifold
  • "LS1" 90-millimeter throttle body
  • Holley Performance Products MSD "LS1" coil packs
  • Walbro 450 LHP in-tank fuel pump
  • Radium Engineering fuel surge tank
  • Dual Walbro 450 LHP fuel pumps in the surge tank
  • Dual fuel filters
  • Aeromotive fuel pressure regulator
  • Bosch 2200cc fuel injectors
  • Flex fuel sensor
  • CXRacing turbo manifold
  • MAC 4-port boost controller
  • Borg Warner S366 turbocharger
  • TiAL 50-millimter blow-off valve
  • Precision Turbo and Engine 46-millimeter wastegate
  • 3-inch stainless-steel exhaust system
  • General Motors "T56" Stage 2 6-speed manual transmission
  • Custom-made adapter plate
  • Tilton Engineering clutch master cylinder and hydraulic throw-out bearing
  • McLeod Racing twin-disc clutch
  • DriveShaft Shop aluminum driveshaft
aregister
panhandle of WV
Hybrid Jetta 2013
rebuilt title. interesting car but seems like a money pit. not sure why they are selling. Also, seller says he "guessed" on registration mileage and doubled the actual value? weird.
okMK
Gti
Yea, lots of sketchy stuff going on in that auction. From what I can tell the rebuilt title accident was prior to work, but who knows. Also, the owner "doesn't know" when the intercooler got dented. Seems like a good bit of accountability is out of the window with this car, and the bid website doesn't care much to ask questions. No telling what could be wrong with this thing.
