235/45r17 tire on a 7.5" or 8" rim?
mrmatto
Jacksonville, FL
2024 GTI DSG
For street. My gut tells me 8" width would better support the tire and 7.5" would be too floppy. Buuuuut there are a lot more 17x7.5 options. I'm curious what you 17"-ers have experienced.
(235/45r17 is closest to stock size and I'm stock ride height)
khail19
Reno NV
2016 GTI SE
Definitely 8". My winter wheels are 7.5" with 205/50R17. No way I would want a 235 on this wheel.
ZERO815
Köln Germany
2017 GTI SE DSG
According to the ETRTO the recommended wheel size is 8, it‘s possible to use 7.5-9 also.
  • etrto-reifen-liste.pdf
Oscar LaVista
Mt Kisco, NY & Weeki Wachee FL
2018 GTI SE 6MT
I went from 235/45/17 on 8.5" to the same tires on factory 7.5". I could feel the difference the week I switched, but got used to it pretty quickly and now it's fine, and I don't drive gently. No issues with tire wear. I'm just a regular person who drives every day in regular situations, and I scuffed my 8.5" Neuspeeds when parallel parking because the edge of the rim was even with or slightly beyond the sidewall of the tire. I HATED that. I have not scuffed the 7.5" wheels. I'm happy with my choice, so it just depends on your use of the car and your expectations. An 8" wheel is probably ideal, but as you found, there aren't many choices. I originally chose the Neuspeeds because they have a reputation for being durable and reasonably light, had stock hub diameter and took stock bolts. And then they started discontinuing their 17" wheels, including the ones I had...
