2019 Stock Englishtown Center Wheel cap
El Golfo
Texas
Does anyone know the part number for the stock wheels on a 2019 Golf R? Lost one of mine and looking to replace it.
OldVWFan
NW Arkansas
17 GTI Sport
No, I read your title incorrectly. The center cap I would think would be the same for all VW wheels with a 57.1 mm center bore. My wheel center cap has the part number 5G0 601 171 and 5G0 601 171 B. This is from a 17 GTI Sport with 18" Nogaro wheels.
El Golfo
Texas
Thank you sir
sijray21
northern va
Thank you sir
Center Bore is only for the hub-side. The cap-side is different. I believe the Englishtowns are 66mm outer diameter caps.
i'm looking now, but be careful. not all VW wheels are the same. i have a set of Englishtowns and Pretorias (19") and they have different center caps that are sized differently. The Pretorias have a smaller cap-size than the Englishtowns as an example.
El Golfo
Texas
You're right. I double checked and the ones listed above don't fit the 19' Englishtowns. The correct part number for the cap on the Englishtowns is 6C0 601 171
