2019 SE with 6500 miles throwing codes for the turbo.. help (attached log from obd11)
Blindeye_03
North KY
My EPC light illuminates on the gauge cluster and my infotainment says the start/stop isnt working right. Then I see on the performance page that I have 0 boost pressure and the car is slow as hell.. I managed to reset the codes tonight but if i take it to VW with no EPC light can they still pull the codes and fix my car? Or do I need to drive it in limping with no boost?
I am COMPLETELY stock aside from some obd11 tweaks like my fogs/drls staying on for 30seconds after turning the car off and my soundaktor being disabled.
Here is the log:
Fault
Control unit: 01 Engine
Active faults: 0
Inactive faults: 3
System description: 2.0l R4 TFSI
Software number: 5G0906259Q
Software version: 0002
Hardware number: 06K907425J
Hardware version: H13
ODX name: EV_ECM20TFS0205G0906259Q
ODX version: 001003
Faults:
P00AF00 - Turbocharger/Supercharger Boost Control "A" Module Performance
static
Date: 2020-08-18 22:22:02
Mileage: 10410 km
Priority: 2
Malfunction frequency counter: 1
Unlearning counter: 255
Engine speed: 765.25 1/min
Normed load value: 14.5 %
Vehicle speed: 0 km/h
Coolant temperature: 58 °C
Intake air temperature: 28 °C
Ambient air pressure: 980 mbar
Voltage terminal 30: 12.285 V
Dynamic environmental data: 2096283EAA003EA80DC03EA609FB3EA727EF3EA9D8F03EAB5C40180106
P256300 - Turbocharger Boost Control Position Sensor Circuit Range/Performance
static
Date: 2020-08-18 22:21:54
Mileage: 10410 km
Priority: 2
Engine speed: 0.00 1/min
Normed load value: 0.0 %
Coolant temperature: 57 °C
Voltage terminal 30: 12.304 V
Dynamic environmental data: 2096283EAA013EA80DA03EA600003EA727FF3EA9F3A83EAB5C40180104
P004500 - Turbocharger/Supercharger Boost Control "A" Circuit/Open
static
Mileage: 10410 km
Priority: 2
Vehicle speed: 255 km/h
Dynamic environmental data: 2096283EAA003EA80DA03EA600003EA727FF3EA900003EAB5C40180107
Mileage: 10410 km
Date: 2020-08-18 22:27
Blindeye_03
North KY
Ok well my question still stands.... I get that.
When I Google these codes it's my wastegate or turbo. I'm pretty sure my soundaktor or headlights wouldn't cause the wastegate to be stuck open.
Nothing new has been coded aside from start/stop which I did re-enable 4 days ago now. And the code reappeared.
So again. Do I take my car in reversing every thing? Do they need to see the epc light or can they pull codes after I've cleared them?
norsairius
United States Midwest
2019 GTI SE DSG
Do the OBD11 tweaks really lead to concerns with warranty or something? I could see maybe if the tweaks impacted the engine somehow like maybe the engine response app or even the throttle response one, but the ones OP did seem fairly harmless.
I’m interested because I ordered an OBD11 but I also want to make sure that I don’t do anything that could void my warranty.
Otherwise, OP: as Diggs24 said, just make sure the warning light is on When you take the car in. No need to wait a week if it comes on sooner. Good luck, keep us posted!
Blindeye_03
North KY
Yeah I'm confused about that too. I turned my hazard light down too. Like these are silly mods. I'll revert them but yeah the first appointment I could make was for next Monday.
I've reset it twice now.
Blindeye_03
North KY
Nevermind. It won't clear now. This will be fun driving for a week.
This is the worst possible timing that this could have ever happened. I'm hoping another vw dealer will get me in sooner but my schedule also sucks ass.
norsairius
2019 GTI SE DSG
It's a MK7.5. They do weird shit when you mess with the coding.
Well, dang. I was hoping to at least be able to use the key fob to lock the car while the engine is running and maybe a couple other tweaks, but I'm too paranoid about voiding the warranty with any of the electronics or the powertrain. Maybe I'll just stick to cosmetics for now. Too bad I already ordered an OBD11 from ShopDAP. I guess I can keep it just in case I need to read codes and whatnot (though I hopefully won't need it for that either, knock on wood). Maybe I'll ask my dealer and see what they say.
Sorry I took your thread a bit off topic, OP. Hope the issue is easily resolved! Let us know how it goes and if your dealer mentions anything about the OBD11 tweaks (or not). I wonder if they can tell anything's been done even if you reverted the changes?
Blindeye_03
North KY
Just a quick update.. No more light and I have boost. For now... I'm keeping my vw appointment though.
I'd they scan my car, can they see that I had the codes before I cleared them? I'm guessing no?
