But oil viscosity!!!
Are you a mechanical or software engineer for VW? Or one at all?Are you mentally retarded? We still don't know if the documented issue with actual and reported oil pressure is resolved. It's awesome that the ECU update has resolved the stalling issue and the car runs smoother, but the ECU not getting correct values is a pretty big thing. If this isn't fixed and VW worked around it with the ECU flash, I wouldn't consider that a good solution.
There's no need to ask if someone is mentally retarded. Corprin is well regarded in the forum and asked a legitimate question.
He’s absolutely right. I have yet to make one actual contribution to the mk7 community. Maybe I could contribute by authoring a thread that regurgitates the findings and work of others?
The fact is, GTIfan99 knows nothing of my resume, nor others, while criticizing for anything close to a disagreement with his staunch positions.
It’s cool, I’ve dealt with people like him in the past. The fact remains I’ve forgotten more about building and tuning cars/chassis/tracks then he’ll ever know... or regurgitate as it may be.
But yeah, it’s the pressure of oil and timing lies to the ECU that caused the unknown problem with Pluto not being a planet and the moon landing flat earth.
Again, are you an engineer? If not, take your flash and quit pushing some perceived problem other than the one that the cars quit stalling.The oil pressure discrepancy isn't a conspiracy, though it may not of had anything to do with stalling and you’re disappointed with that result.
That doesn't make it a none issue. You guys are pretty thick.
The stalling problem is now a non-issue. They can release what they edited in the code or not, but the problem is fixed. Changing to something not 0W-20 wasn’t the fix, so it seems pretty thick to suggest that it is still an issue based on the urban legend that some people quit stalling when they switched (correlation != causation).
Unless I missed that complaint, there was none to fix.I'm not claiming they still stall. During the process of trying to figure all this out, it was discovered that there's an oil pressure discrepancy.
Let's say you have surgery you remove you're gsll bladder, and they find a tumor. You don't ignore the tumor.
So they've fixed the stall. Awesome. Did it also fix the oil discrepancy?
Tell you what, have 150+ people complain to NHTSA about some sort of oil pressure discrepancy and then YOU can write a petition to ask them to open an investigation and get VW to fix the problem that may, or may not, exist.I'm not claiming they still stall. During the process of trying to figure all this out, it was discovered that there's an oil pressure discrepancy.
