Twist1
- Breaking Mustang Hearts
Launch the car at WOT with all nanies off and video it. Any issues you're gonna see pretty fast lol or its gonna spin for 60 feet straight
You're being way too philosophical about this.
Scan the car and see what's wrong with it. You can disable torque nannies in first but what you're describing sounds like something is going on. My brand-new 18 would break loose even at half throttle in first gear and second would be close to traction limit.
If the car is brand spanking new it is quite possible there is an engine break in hard reduction in power. It's more than likely for the transmission more so in high torque gears (1st).
I can't say I've ever seen such a display of soliloquy about something so trivial.
Had 24 miles on it when it showed up. I'm accounting for that, and the way new vehicles, new brakes, new clutches, and new engines behave.
Going into great detail about the specific issues I've observed will be helpful to someone in the future. People have trouble explaining this sort of thing, so I've explained it in many different ways; it's also fun. Takes everything I've got right now to get out and about, because I'm not doing so hot. When I come back, I want to discuss what I've observed. It's fun. Between driving and talking about the drive, that's all the fun I get now.
If it turns out there's something wrong with the vehicle, that's helpful, as well.
It'll be heading to the dealer at 500 miles for a new round of fluids, and given I've had to do a lot of location scouting recently, that should be coming up very soon. I intend to have the whole thing checked out.
Even so, I'm not feeling a mechanical problem so much as I am limitations being applied. I think there was indeed a "break-in" mode, and I feel like that's been eclipsed, as between one drive and another, the car immediately began to behave a bit better. I can only launch the thing so hard right now; I need to wait for that thousand, but I can darn well still get it in it's power band. I know where this power should be coming in, and it's being limited.
It's patently obvious behind the wheel.
I'm not trying to burn out. I'm just on a journey to get the computers out of my way so I can actually drive the car. I, like everyone else, spent many years developing that skill, and I don't intend to let this car waste them.
I've driven enough cars to know when one is slapping me on the wrist and hiding the cookies.
Minor weight reduction and a raw driving feelLmao. Ecu delete xD
OP I think it's normal and you'll get it figured out. Just wait till you're tuned and you're gonna miss these days when you could actually hook from a stop lol
Better tires, lighter wheels.
What rpm are you shifting at? If you're following the break in and shifting under 4k 1st and 2nd are pretty tame.
Lay on it to 6k in both gears. Unless the road is amazing you should see the ASR light up at the top of the gears. Stock power should break the stock tires free pretty easily.
In case it wasn't mentioned already, look into a pedal tuner.. i was also very frustrated with the throttle response and did every OBD11 mod possible for it and still wasnt enough so i bought the BMS pedal tuner and it fixed all of the throttle lag and input delays that were driving me nuts.. i currently have it on race mod +2 and very satisfied.
Link: https://burgertuning.com/products/bms-pedal-tuner
I'm just bidding time and planning for a clutch.
SMFW and LSD FTW
