I had obdeleven scan while waiting for VAG COM to arrive. Here are the results.
First as it sat then after trying clearing all codes and rescan.
FIRST SCAN
OBDeleven data log
Date: 2020-11-14 11:58
VIN: 3VW447AU7JM287543
Car: Volkswagen Golf GTI Original
Year: 2018
Body type: 3-dr hatchback
Engine: CXCB
Mileage: 20180 KM
01 Engine
System description: 2.0l R4 TFSI
Software number: 5G0906259L
Software version: 0002
Hardware number: 06K907425B
Hardware version: H13
ODX name: EV_ECM20TFS0205G0906259L
ODX version: 001004
Long coding: 091D00122424012F1000
Trouble codes:
P048000 - Cooling Fan 1 Control Circuit
static
Date: 2020-08-26 12:48:04
Mileage: 20180 km
Priority: 2
Malfunction frequency counter: 1
Unlearning counter: 255
Engine speed: 0.00 1/min
Normed load value: 0.0 %
Vehicle speed: 255 km/h
Coolant temperature: 15 °C
Intake air temperature: 17 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 14.394 V
Dynamic environmental data: 209628110E0011EC0011DC000011ED6510A6019911EE2911DB0AF0
P019000 - Fuel Rail Pressure Sensor "A" Circuit
Intermittent
Date: 2020-08-26 12:48:06
Mileage: 20180 km
Priority: 2
Malfunction frequency counter: 11
Voltage terminal 30: 14.238 V
P019200 - Fuel Rail Pressure Sensor "A" Circuit Low Input
Intermittent
Date: 2020-08-26 12:55:17
Mileage: 20180 km
Priority: 2
Malfunction frequency counter: 3
Intake air temperature: 19 °C
Voltage terminal 30: 14.160 V
Dynamic environmental data: 209628110E0011EC0011DC000011ED6510A6019911EE2911DB0000
U110300 - Production mode active
static
Priority: 2
Vehicle speed: 0 km/h
Ambient air pressure: 0 mbar
Voltage terminal 30: 0.000 V
Dynamic environmental data: 209628110E0011EC0011DC000011ED0010A6000011EE0011DB0000
P023600 - Turbocharger Boost Sensor (A) Circ. Range/Performance
static
Date: 2020-08-26 12:56:11
Mileage: 20180 km
Priority: 2
Voltage terminal 30: 14.257 V
Dynamic environmental data: 209628110E0011EC0111DC000011ED6410A6019911EE2911DB0000
P063800 - Throttle Actuator Control (Bank1) Range/Performance
Intermittent
Priority: 2
Malfunction frequency counter: 6
Voltage terminal 30: 13.964 V
P226300 - Turbocharger/Supercharger Boost System Performance
Intermittent
Priority: 2
Voltage terminal 30: 2.968 V
Dynamic environmental data: 2096283EAA003EA83E003EA600003EA703083EA9F1833EAB5B64180104
U013100 - Lost Communication With Power Steering Control Module
static
Date: 2020-08-26 12:48:03
Mileage: 20180 km
Priority: 6
Malfunction frequency counter: 2
Dynamic environmental data: 209628110E0016E000202F0B4111A8000011AB00004383200011DC0000
U012100 - Lost Communication With Anti-Lock Brake System (ABS) Control Module
static
Mileage: 20180 km
Priority: 2
U010100 - Lost Communication with TCM
static
Mileage: 20180 km
Priority: 2
02 Transmission
Trouble codes:
No trouble codes found
03 Brakes
Trouble codes:
08 Air Conditioning
System description: Climatronic
Software number: 5GM907044G
Software version: 2001
Hardware number: 5GM907044G
Hardware version: H04
ODX name: EV_ACClimaBHBVW37X
ODX version: 006146
Long coding: 0002001420011801100400000010140E
Trouble codes:
U112100 - Databus missing message
static
Date: 2020-08-26 10:26:15
Mileage: 20180 km
Priority: 6
09 Central Electrics
System description: BCM PQ37BOSCH
Software number: 5Q0937087AR
Software version: 0246
Hardware number: 5Q0937087AN
Hardware version: 034
Serial number: C86424051801AB
ODX name: EV_BodyContrModul1UDSBosc
ODX version: 018001
Subsystems:
System description: WWS 180329
Software version: 0551
Hardware version: 043
Serial number: 97022066180407075657
Long coding: 0E4DDD
System description: RLHS
Software version: 0107
Hardware version: 050
Serial number: SAY18M05D16H22M42S32
Long coding: 00A8DD
System description: J245 PS60.006
Software version: 0170
Hardware version: H07
Serial number: 03691622512208171646
Long coding: 181803
Trouble codes:
Intermittent
Date: 2020-08-26 13:36:10
Mileage: 20180 km
Priority: 6
Unlearning counter: 65
Terminal 15 status: On
Terminal 50 status: Off
Voltage: 14.2 V
Outside air temperature: 18.0 °C
Status Bremslichtschalter (HW): Off
Status Bremslichtschalter (CAN): Off
Off: operated
Parking light: not activated
Automatic high beam assist: not activated
Low beam: not activated
Parking light left: not activated
Parking light right: not activated
Letzte Weckursache/ Werte [00;2E]: keine Störschutzursache
CAN-Bus_aktiv: On
Intermittent
Mileage: 20180 km
Priority: 6
Voltage: 14.2 V
Off: operated
CAN-Bus_aktiv: On
Intermittent
Mileage: 20180 km
Priority: 6
Voltage: 14.2 V
Off: operated
CAN-Bus_aktiv: On
Intermittent
Mileage: 20180 km
Priority: 6
Voltage: 14.2 V
Off: operated
CAN-Bus_aktiv: On
Intermittent
Mileage: 20180 km
Priority: 6
Voltage: 14.3 V
Off: operated
CAN-Bus_aktiv: On
static
Date: 2020-08-26 10:26:19
Mileage: 20180 km
Priority: 6
Voltage: 14.1 V
Outside air temperature: 15.0 °C
Off: operated
CAN-Bus_aktiv: On
static
Mileage: 20180 km
Priority: 6
Voltage: 13.9 V
Off: operated
CAN-Bus_aktiv: On
static
Mileage: 20180 km
Priority: 6
Voltage: 14.0 V
Off: operated
CAN-Bus_aktiv: On
static
Mileage: 20180 km
Priority: 6
Malfunction frequency counter: 5
Voltage: 13.9 V
Off: operated
CAN-Bus_aktiv: On
static
Mileage: 20180 km
Priority: 6
Voltage: 14.0 V
Off: operated
CAN-Bus_aktiv: On
Intermittent
Mileage: 20180 km
Priority: 6
Voltage: 14.2 V
Off: operated
CAN-Bus_aktiv: On
Intermittent
Mileage: 20180 km
Priority: 6
Voltage: 14.2 V
Off: operated
CAN-Bus_aktiv: On
Intermittent
Mileage: 20180 km
Priority: 6
Voltage: 14.3 V
Off: operated
CAN-Bus_aktiv: On
Intermittent
Mileage: 20180 km
Priority: 6
Voltage: 14.2 V
Off: operated
CAN-Bus_aktiv: On
static
Mileage: 20180 km
Priority: 6
Voltage: 14.0 V
Off: operated
CAN-Bus_aktiv: On
static
Mileage: 20180 km
Priority: 6
Voltage: 13.9 V
Off: operated
CAN-Bus_aktiv: On
Intermittent
Mileage: 20180 km
Priority: 6
Voltage: 14.2 V
Off: operated
CAN-Bus_aktiv: On
Intermittent
Mileage: 20180 km
Priority: 6
Voltage: 14.2 V
Off: operated
CAN-Bus_aktiv: On
Intermittent
Mileage: 20180 km
Priority: 6
Voltage: 14.2 V
Off: operated
CAN-Bus_aktiv: On
Intermittent
Mileage: 20180 km
Priority: 6
Voltage: 14.2 V
Off: operated
CAN-Bus_aktiv: On
Intermittent
Mileage: 20180 km
Priority: 6
Voltage: 14.2 V
Off: operated
CAN-Bus_aktiv: On
Intermittent
Mileage: 20180 km
Priority: 6
Voltage: 14.2 V
Off: operated
CAN-Bus_aktiv: On
Intermittent
Mileage: 20180 km
Priority: 6
Voltage: 14.2 V
Off: operated
CAN-Bus_aktiv: On
Intermittent
Mileage: 20180 km
Priority: 6
Voltage: 14.2 V
Off: operated
CAN-Bus_aktiv: On
Intermittent
Mileage: 20180 km
Priority: 6
Voltage: 14.2 V
Off: operated
CAN-Bus_aktiv: On
Intermittent
Mileage: 20180 km
Priority: 6
Voltage: 14.2 V
Off: operated
CAN-Bus_aktiv: On
static
Mileage: 20180 km
Priority: 6
Voltage: 14.1 V
Off: operated
CAN-Bus_aktiv: On
U111400 - Component protection GFA key
Intermittent
Date: 2020-08-26 13:30:38
Mileage: 20180 km
Priority: 1
Voltage: 14.2 V
Off: operated
CAN-Bus_aktiv: On
15 Airbag
System description: AirbagVW20
Software number: 5Q0959655T
Software version: 0830
Hardware number: 5Q0959655T
Hardware version: 011
Serial number: 003MHM04EYM9
ODX name: EV_AirbaVW20SMEVW37X
ODX version: 002144
Long coding: 8CCCFC00000000005000001AC24800000065
Subsystems:
System description: BF-Gewichtss.
Software version: 0022
Serial number: IBH0000000000095193U
Long coding: 30305A
System description: SideSensor_Df
Software version: 0887
Hardware version: 001
Serial number: 35700000000BC09C5D2-
Long coding: 2D2D2D
System description: SideSensor_Pf
Serial number: 358000000007D09C5D2Y
Long coding: 2D2D2D
System description: SideSensor_Dr
Software version: 6149
Hardware version: 000
Serial number: 35100019F29E7325D5EM
Long coding: 2D2D2D
System description: SideSensor_Pr
Serial number: 3520001A329E7324B1E5
Long coding: 2D2D2D
System description: FrontSensor_D
Serial number: 3550001B129E65D493BG
Long coding: 2D2D2D
System description: FrontSensor_P
Serial number: 3560001B129E65D292AD
Long coding: 2D2D2D
Trouble codes:
B10B300 - Function restriction of seat occupied recognition due to implausible message
static
Date: 2020-08-26 10:26:29
Mileage: 20180 km
Priority: 2
Malfunction frequency counter: 20
B10B200 - Function restriction of seat occupied recognition due to missing message
static
Date: 2020-08-26 10:26:14
Mileage: 20180 km
Priority: 2
B13BCF2 - Multiple collision brake No function
static
Date: 2020-08-26 10:26:13
Mileage: 20180 km
Priority: 2
static
Mileage: 20180 km
Priority: 6
static
Mileage: 20180 km
Priority: 6
16 Steering Column
System description: Lenks. Modul
Software number: 5Q0953507HL
Software version: 0140
Hardware number: 5Q0953549E
Hardware version: 003
Serial number: 12041804401268
ODX name: EV_SMLSKLOMQB
ODX version: 020002
Long coding: 0410
Trouble codes:
17 Dashboard
System description: KOMBI
Software number: 5G1920756C
Software version: 0310
Hardware number: 5G1920756C
Hardware version: 342
ODX name: EV_DashBoardVDDMQBAB
ODX version: 009060
Long coding: 0BAD091AA980880902086B0010000000A0000000
Trouble codes:
U140100 - Function restriction due to excessive voltage
Intermittent
Date: 2020-10-08 00:00:36
Mileage: 20180 km
Priority: 6
U110000 - Component protection No basic setting
Intermittent
Date: 2020-08-26 13:30:20
Mileage: 20180 km
Priority: 4
static
Date: 2020-08-26 10:26:16
Mileage: 20180 km
Priority: 2
static
Mileage: 20180 km
Priority: 6
static
Mileage: 20180 km
Priority: 2
static
Mileage: 20180 km
Priority: 6
B104A00 - Engine/Motor Control Module 1/power electronics 4 not authorized
Intermittent
Date: 2020-08-26 10:51:18
Mileage: 20180 km
Priority: 1
static
Mileage: 20180 km
Priority: 2
19 Gateway
System description: GW MQB High
Software number: 3Q0907530L
Software version: 5323
Hardware number: 3Q0907530C
Hardware version: 518
Serial number: 23051800840242
ODX name: EV_GatewNF
ODX version: 013023
Long coding: 030100047F085900FB00026B1C0F00010001070000000000000000000000
Subsystems:
System description: E221__MFL-DC1
Software version: 0103
Hardware version: H11
Serial number: 29170002051680087383
Long coding: 31FFFF
Trouble codes:
U021200 - Lost Communication With Steering Column Control Module
Intermittent
Date: 2020-08-26 13:36:11
Mileage: 20180 km
Priority: 2
Supply voltage, terminal 30: 14.1 V
Terminal 15: On
U014000 - Lost Communication With Body Control Module
Intermittent
Mileage: 20180 km
Priority: 2
Terminal 15: On
U101D00 - Power steering control module No communication
static
Date: 2020-09-12 00:00:42
Mileage: 20180 km
Priority: 2
Malfunction frequency counter: 4
Supply voltage, terminal 30: 12.3 V
Terminal 15: On
static
Mileage: 20180 km
Priority: 2
Terminal 15: On
U015500 - Lost Communication With Instrument Panel Cluster (IPC) Control Module
Intermittent
Mileage: 20180 km
Priority: 2
Terminal 15: On
U104000 - Axle differential lock control module No communication
static
Mileage: 20180 km
Priority: 2
Terminal 15: On
U10A400 - Electronic Steering Column Lock Control Module No communication
Intermittent
Mileage: 20180 km
Priority: 2
Terminal 15: On
U016400 - Lost Communication With HVAC Control Module
Intermittent
Mileage: 20180 km
Priority: 2
Terminal 15: On
U019900 - Lost Communication With "Door Control Module A"
Intermittent
Mileage: 20180 km
Priority: 2
Terminal 15: On
U020000 - Lost Communication With “Door Control Module B”
Intermittent
Mileage: 20180 km
Priority: 2
Terminal 15: On
U010000 - Lost Communication with ECM/PCM
Intermittent
Date: 2020-08-26 11:06:55
Mileage: 20180 km
Priority: 2
Terminal 15: Off
static
Mileage: 20180 km
Priority: 2
Terminal 15: On
U112600 - Undefined control module No communication
Intermittent
Mileage: 20180 km
Priority: 2
Terminal 15: On
U000200 - High Speed CAN Communication Bus Performance
Intermittent
Mileage: 20180 km
Priority: 2
Terminal 15: On
U006500 - Vehicle Communication Bus E Performance
Intermittent
Mileage: 20180 km
Priority: 2
Terminal 15: On
U004700 - Vehicle Communication Bus C Performance
Intermittent
Mileage: 20180 km
Priority: 2
Terminal 15: On
U10AE00 - Suspension data bus Single wire mode
static
Date: 2020-09-12 00:00:41
Mileage: 20180 km
Priority: 2
Supply voltage, terminal 30: 12.2 V
Terminal 15: On
U10A900 - Suspension data bus Faulty
static
Date: 2020-08-26 10:26:17
Mileage: 20180 km
Priority: 1
Malfunction frequency counter: 61
Supply voltage, terminal 30: 13.9 V
Terminal 15: On
U103000 - Local data bus Electrical error
static
Mileage: 20180 km
Priority: 2
Supply voltage, terminal 30: 13.8 V
Terminal 15: On
Intermittent
Date: 2020-08-26 13:30:02
Mileage: 20180 km
Priority: 4
Terminal 15: On
29 Light Control Left
System description: LCM_MLBevo���
Software number: 8V0907399D
Software version: 0014
Hardware number: 8V0907399D
Hardware version: H08
ODX name: EV_LCMLeftHELLAAU736
ODX version: 001012
Trouble codes:
static
Date: 2020-08-26 10:26:18
Mileage: 20180 km
Priority: 6
Malfunction frequency counter: 13
2B Steering Column Lock
System description: ELV-MQBA
Software number: 5Q0905861A
Software version: 0120
Hardware number: 5Q0905861A
Hardware version: H01
Serial number: 18000102061008
ODX name: EV_ELVMarquMQB
ODX version: 004111
Long coding: 5D00000000000000
Trouble codes:
static
Date: 2020-08-26 10:26:20
Mileage: 20180 km
Priority: 6
ELV State: 4
Information Clamps: 7760
CoCo State: e001
WFS State: 1706
Vehicle speed: 655.34 km/h
Voltage: 7c
AD-Value H-bridge: 3b
Clamp15 flip flop, SSTx, button contacts: 6
CAN signals: 5
32 Lock Electronics
Trouble codes:
39 Light Control Right
ODX name: EV_LCMRightHELLAAU736
ODX version: 001012
Trouble codes:
static
Mileage: 20180 km
Priority: 6
42 Driver Door
System description: TSG FS
Software number: 5Q4959593E
Software version: 0032
Hardware number: 5Q4959593B
Serial number: 5038814800726
ODX name: EV_DCUDriveSideEWMAXCONT
ODX version: 006001
Long coding: 003E13200000020000000000
Subsystems:
System description: Fond FHSG DRV
Software version: 0004
Hardware version: 010
Serial number: 00000000000000421787
Long coding: 011000
Trouble codes:
B148754 - Motor for window regulator No basic setting
static
Date: 2020-08-26 10:25:40
Mileage: 20180 km
Priority: 3
B131FF5 - Rear window regulator, driver side Voltage supply lower limit not reached
Intermittent
44 Steering Assistance
Trouble codes:
4B Multifunction Module
System description: FCM MQB Low
Software number: 3Q0907338
Software version: 0286
Hardware number: 3Q0907338
Hardware version: 002
Serial number: 26031800840682
ODX name: EV_MultiModulContiVW48X
ODX version: 001010
Long coding: 000000050100214A01110F01030000000000000000000000000000000000
Trouble codes:
static
Mileage: 20180 km
Priority: 6
Unknown ambient data: 8B0000008000
static
Mileage: 20180 km
Priority: 6
U140000 - Function restriction due to insufficient voltage
Intermittent
Priority: 6
Unlearning counter: 40
Unknown ambient data: 340000000000
52 Passenger Door
System description: TSG BFS
Software number: 5Q4959592E
Hardware number: 5Q4959592B
Serial number: 6038815200236
ODX name: EV_DCUPasseSideEWMAXCONT
ODX version: 006001
Subsystems:
System description: Fond FHSG PSG
Serial number: 00000000000000417958
Long coding: 091000
Trouble codes:
B1320F5 - Rear window regulator, front passenger side Voltage supply lower limit not reached
Intermittent
Date: 2020-10-08 00:00:10
Mileage: 20180 km
Priority: 2
5F Multimedia
System description: MU-S-NS-US
Software number: 3Q0035876B
Software version: 0867
Hardware number: 3Q0035876B
Hardware version: 851
Serial number:
ODX name: EV_MUStd4CDELP
ODX version: 001001
Long coding: 027310020000000051220002001828009F0503F401200505C6
Subsystems:
System description: ABT_Std-2_Nav
Software version: 8130
Hardware version: H52
Serial number: VWZ6ZJV1100765
Trouble codes:
Intermittent
Date: 2020-10-08 00:00:42
Mileage: 20180 km
Priority: 6
Dynamic environmental data: 0286B9
Intermittent
Date: 2020-08-26 13:30:52
Mileage: 20180 km
Priority: 4
Dynamic environmental data: 02868E
B126CF2 - Navigation system Navigation database not enabled
Intermittent
Date: 2020-08-26 13:30:53
Mileage: 20180 km
Priority: 6
Dynamic environmental data: 02868D
B11CF53 - Tuner for satellite radio Deactivated
static
Mileage: 20180 km
Priority: 4
Dynamic environmental data: 02868B4FF70000006800010202
static
Mileage: 20180 km
Priority: 6
Dynamic environmental data: 02868A186001
U111100 - Function limitation due to missing message
static
Date: 2020-11-12 00:01:31
Mileage: 20180 km
Priority: 6
Dynamic environmental data: 028677184402
static
Mileage: 20180 km
Priority: 6
A9 Structure Borne Sound
System description: SAS-GEN 2
Software number: 5G0907159G
Software version: 0001
Hardware number: 4H0907159A
Serial number: 180320200703
ODX name: EV_SoundActuaGen2AU64X
ODX version: 003010
Trouble codes:
static
Mileage: 20180 km
Priority: 6
B7 Start System Interface
System description: VWKESSYMQB
Software number: 5Q0959435C
Software version: 0803
Hardware number: 5Q0959435
Hardware version: 021
Serial number: 0471877433
ODX name: EV_KessyHellaMQBAB
ODX version: 002020
Long coding: 032C0C
Trouble codes:
U101100 - Supply voltage Voltage too low
Intermittent
Priority: 4
Intermittent
Mileage: 20180 km
Priority: 6
Intermittent
Mileage: 20180 km
Priority: 6
Intermittent
Mileage: 20180 km
Priority: 6
Intermittent
Mileage: 20180 km
Priority: 6
Intermittent
Mileage: 20180 km
Priority: 6
Intermittent
Mileage: 20180 km
Priority: 6
Intermittent
Mileage: 20180 km
Priority: 6
Intermittent
Mileage: 20180 km
Priority: 6
Intermittent
Mileage: 20180 km
Priority: 6
Intermittent
Mileage: 20180 km
Priority: 6
Intermittent
Mileage: 20180 km
Priority: 6
Intermittent
Mileage: 20180 km
Priority: 6
Intermittent
Mileage: 20180 km
Priority: 6
Intermittent
Mileage: 20180 km
Priority: 6
D6 LED Module Left
System description: LED1L
Software number: 7P5941572A
Hardware number: 7P5941572A
Hardware version: H06
ODX name: EV_LEDMinMaxL_KEBODAVW481
ODX version: 001003
Trouble codes:
D7 LED Module Right
System description: LED1R
ODX name: EV_LEDMinMaxR_KEBODAVW481
ODX version: 001003
Trouble codes:
SECOND SCAN
OBDeleven data log
Date: 2020-11-14 12:04
Year: 2018
Engine: CXCB
Mileage: 20180 KM
01 Engine
ODX version: 001004
Trouble codes:
static
static
static
static
02 Transmission
Trouble codes:
03 Brakes
Trouble codes:
08 Air Conditioning
ODX version: 006146
Trouble codes:
ODX version: 018001
Subsystems:
Long coding: 0E4DDD
Long coding: 00A8DD
Long coding: 181803
Trouble codes:
static
static
static
static
static
static
static
static
15 Airbag
ODX version: 002144
Subsystems:
Long coding: 30305A
Long coding: 2D2D2D
Long coding: 2D2D2D
Long coding: 2D2D2D
Long coding: 2D2D2D
Long coding: 2D2D2D
Long coding: 2D2D2D
Trouble codes:
static
static
16 Steering Column
ODX version: 020002
Long coding: 0410
Trouble codes:
17 Dashboard
ODX version: 009060
Trouble codes:
static
static
static
static
static
19 Gateway
ODX version: 013023
Subsystems:
Long coding: 31FFFF
Trouble codes:
static
ODX version: 001012
Trouble codes:
ODX version: 004111
Trouble codes:
32 Lock Electronics
Trouble codes:
ODX version: 001012
Trouble codes:
42 Driver Door
ODX version: 006001
Subsystems:
Long coding: 011000
Trouble codes:
Trouble codes:
ODX version: 001010
Trouble codes:
static
static
52 Passenger Door
ODX version: 006001
Subsystems:
Long coding: 091000
Trouble codes:
5F Multimedia
Serial number:
ODX version: 001001
Subsystems:
Trouble codes:
ODX version: 003010
Trouble codes:
static
ODX version: 002020
Long coding: 032C0C
Trouble codes:
D6 LED Module Left
ODX version: 001003
Trouble codes:
D7 LED Module Right
ODX version: 001003
Trouble codes:
Noted that this is a 5 door vehicle and not a 3 door vehicle
Any direction would be appreciated.
