Those wheels are a great deal/look good. Glad you finally got them/spacer issue sorted. I think about buying a second set and mounting summer performance tires on them....Yes...definitely solid FBO status and looks awesome....great job on OEM+++! I'm throwing on the same shoes today so I'll be your little bro around town.
These might become my summer sets....JerseyDrew is hooking me up with some winter wheels on AS3+, but I'll have to run these until I can link up with him. With these wheels at ET45, I think that rub issue I had will be long gone...going to keep the 15mm spacer in back...might need a spacer up front to flush out. We'll see.Those wheels are a great deal/look good. Glad you finally got them/spacer issue sorted. I think about buying a second set and mounting summer performance tires on them....
For you 4motion guys. Get some rear subframe inserts! I wouldn't bother paying a premium for 034s. Just get the CTS versions. You're welcome.
So you just did the rears? Seems simple and only about $100. Looks kind of like the dogbone inserts - just a metal bit that reduces movement of a rubber bushing.Way bigger difference than I thought they would provide. I agree!
Ok you f'ers....I'm in. I'll wait till they run their next sale and grab a set. Is it hard to remove the original ones?They are essentially 4 little dogbone inserts that require less torque to put in. SOOO EASY. The rear feels more predictable and planted in long sweepers. I also don't get the "clunk" I used to get when I shift hard and quick (I have a manual with a springless 4 puck clutch though). I'm going to say its a no brainer for $99 shipped.
I used ramps, pry bar, impact gun, torque wrench. Took me about 20 min with waiting for blue loctite to dry a little before zapping in the bolts.
note: Do one at at time! Do not remove all the bolts at once!
I want so badly to be accepted with you cool guys...ahahahahahah
I'll take no f'ing clue for $500 Alex...BTW.. you f'ers are making me get an exhaust mod. Can you guess which exhaust mod? Give you a hit.. it's the biggest power adder exhaust mod.
