I saw that the 2021 GTI LED headlights are only rated "A" for "Acceptable" by the IIHS. So, I looked up my 2017 SE, and the HIDs are rated "P" for "Poor"??? Really?? My wife's 2018 Civic (with only 23,000 mi) had headlights that were much worse (I upgraded them, of course.)
So... I was looking at the technical details... and the 2021 distances do indeed seem somewhat better than the 2017 distances. Has anybody driven both years, and noticed any difference? BTW, the 2017 high beams straight ahead seem to come up only slightly short of the "Optimal illumination", and likewise on a 150M and a 250M radius curve. The lows seem to be a bit short, "inadequate" on the gradual curve, but "fair" on the tighter curve.
The 2021 seemed to do better, except that the high beams were "inadequate" on both curves. In no instances do any of the headlights exceed "glare limits".
AHA!! Found the 2022 (MK8) because it is listed differently, not as a GTI but as a Golf GTI. Anyhow... the Autobahn trim is "Acceptable" due to the "High beam assist", the SE is "M" for "Marginal", since it doesn't have that. So, the low-beam curve scores are lower, but everything else looks similar to the Autobahn.
I've been happy with my 2017 SE headlights, at least in comparison with "normal" headlights. I drive on dark roads, so this matters, both low and high beams. I'm not saying that "Good enough is fine, I don't want better"... I've always upgraded my headlights (except these, which are already HID and pretty good). If there are upgrades available for the low beams, I'd consider that... if and when these beams go out.
