xXDavidCXx
- AZ
- 2017 GTI SE DSG
I don't think there is any added NVH from my spherical GC top plates. I think you are avoiding a myth, at least for this car and the available products.
I'd be lying if I said I didn't notice additional NVH from ground control camber plates. I could hear more tire noise and pot holes hit harder.I don't think there is any added NVH from my spherical GC top plates. I think you are avoiding a myth, at least for this car and the available products.
I'd second that. If installed correctly they shouldn't make any *weird* noises, but there's absolutely a difference A to B with regards to road and tire noise, absolutely.I'd be lying if I said I didn't notice additional NVH from ground control camber plates. I could hear more tire noise and pot holes hit harder.
That being said, these changes are so minimal, if anyone is complaining about them, they're most likely installed wrong. Any passengers in my car would not notice a difference.
Ok, so I went to .21 toe out front, 0 toe rear. When I made this change in GS trim, the car was stupid loose afterwards. With the APR springs, it is not stupid loose, but it is better than it was. Still need more front neg camber. I just don't think the Eurosport is going to get me there. I chose it because it would retain factory NVH. In the short term I might actually try a little toe out in the rear just for science.
So I'm going to install the Konis at some point and have the opportunity change camber plates or go a different route all together, but my goal is not to drastically increase NVH. Has anyone here been able to get -3 without adding a lot of NVH? The roads where I live are crap due to all the rain.
CSS is .5 or .1 degree of camber. I can’t remember right now. Let’s say .5 for now. SuperPro LCA is another .5 degree. That’s -1 degree for not additional NVH gain. Lowering more than 1/2-3/4” starts to impact roll centers and bump steer. That is another .25 to .5-degree. The other option is TTRS LCA and ball joints. Not sure on the camber gain there.
Outside of those mods, you start treading aftermarket waters to gain any more camber. No way around it. I’m at -2.5 and feel I need -3 for my NT01’s. With my intention to go to take off slicks -3.5 to -4 degree, hence my choice of Verkline LCA’s.
Currently maxed out at -2.5 on 018k SuperPro LCAs and Vorshlag plates at stock ride heigh. My RHS SuperPro swaybar end links has nibbled the sealant out of the inner fender Weld seam. I thought it may be my Ohlins swaybar mounting tab but it is the back of the balljoint that is making contact. No marks on the Ohlin tab after removal on Saturday. Assuming at full lock in parking lots. The SuperPro endlinks are not very svelte in profile. Another reason for me going to the Verkline LCAs. I can widen the track and stand up my Vorshlag camber plates to give me a little or wiggle room to the inner fender.
As for the camber Plate dreaded NVH. When Installed right you cant tell the difference on smooth roads. Expansion joints and potholes will come through as a solid thump/thwack. No getting around that. Rough concrete highway will sound like noisy R-comp tires (Yoko A048’s/NT01’s). It comes through as increased tire noise. Broken asphalt or concrete is noisy. I avoid potholes like the plague. Up North roads are shit because of the winter weather. If you crank up the volume, all you will feel are potholes and expansion joints. If you hear anything, play some good classic rock.
AND CRANK UP THE VOLUME! There is no vibration. Some increased noise and some harshness when hitting potholes.
CSS swivels and TTRS LCAs and ball joints would be what I would investigate.
Really hoping clutches go through, I'm planning my LSD for the winter and would hate to do all that work only to replace the OEM clutch with another OEM.I think it'll be the LCA's if STH doesn't allow clutches in next change. I'll need a clutch sooner than later, so it'll be of to XSA, which will be fine, because I'll have far more latitude with mods.
They allow intercoolers in OEM locations, which isn't bad for this platform (no FMIC though). The manual GTI is in a pretty good spot with gearing though, my 2nd tops out around 75 which is more than fast enough for most courses. I think the FoST is fast but I haven't seen a competitive build of that or the FiST yet. Piehl won in his WRX and the Audi TT is a rocket as well, but heavier than our cars.Do they allow intercoolers in sth yet? I stopped autocrossing entirely in 2018, and my biggest driving factor was the classing. Seems there's always a poster child for each class and that's what they gear mods towards. Sth seems very fost and fist loving. I was forced into dsp initially because dsg needs a tune to lock you into 2nd gear, and then sth came about with intercooler limitations. For the money I was spending to be competitive in dsp I decided to just focus all of my efforts on track instead.
I agree on the money though, until this point I've tried to pick and choose parts to setup the car to be 85% competitive without breaking the bank, to see if the chassis would be a good fit for the class. So far so good, but the next mods (LSD + potentially clutch) alone will cost more than I've spent to date on other STH parts. There gets to a point though where you hit diminishing returns pretty quickly
Definitely won't talk you out of it. I think it's worth a try to get quicker rotation at AutoXIf they come through with clutches, it'll be awesome.
If not, XS will be fun, duel track/autocross friendly, but car will be uncompetitive and the pax sucks.
Until they figure it all out, talk me out of a little toe out in the rear.
Will it be a low-speed compression / damping change only?Ohlins are out for a custom revalve. Compression curve is going to be tweaked as well. Apparently this can be done indepent of the high speed bump/rebound because of the DFV design. Kinda liking my decision to go wit Ohlins even more. Going to have more headroom built in for track rebound adjustments. The proof will be on the stopwatch around VIR.
