Wisconsin, hence all the road America references.
How are those 034 mounts? I'm looking into doing the eurotek inserts with OEM rubber mounts to keep it a good daily and not have any BS noises and stuff those plates bring (the old GC debacle)
Gotcha. I should be up at road america at some point this year I think. I've got a friend that goes every year and always invites me, but i tend to prioritize a lot of other events first.
The topmounts are pretty good. They're still pretty aggressive in terms of feel. They're not quite as solid as a solid topmount, but the rubber doesn't bend much and the spring/bearing makes contact with metal, not with rubber. As far as daily use, I would take it on if the car is a true track rat (12+ days per year) and you need camber, but otherwise I'd stay stock.
victor,
was wondering what 034 parts you were ditching? how come? i just picked up a gently used set of 034 camber mounts for $175 and was gonna pair them with their springs and RSB... i'd like to do some scca events this spring and have basic suspension mods planned. i can't afford to go overboard or ruin my DD...
I have/had 034 dogbone inserts, p34 intake, rear bar, rear and front endlinks, dynamic + springs, the dynamic+ topmounts, and rear strut mount. The topmounts are the only thing I'm keeping. The rest of everything I'm either replacing with stock, superpro, or the revo bushing in the case of the dogbone.
I absolutely do not tolerate aftermarket promises of "it's as good or better than stock and has no drawbacks" because they're never actually true. The 034 springs and topmounts did not play well together. I was told this may be due to having DCC, but I can't confirm or deny that. the front right endlink keeps coming loose, regardless of amount of loctite on it. The rears one broke, and since i got them to work with the bar when i replaced my st bar +superpro EL with the 034 bar+EL, it felt like a waste. I threw out the endlinks and gave away the bar locally. I'm back on the ST and superpro EL and it's way quieter/tighter feeling. Superpro quality is significantly better. I'm going to their front and rear bar to balance things out soon. The dogbone inserts just had horrible vibrations and noise. It always felt the car was falling apart so I ditched them. The revo is better. P34 was all warped, heat makes it crack around the bolts, the plastic doesn't look oem at all, the filter they send you should only use if you want to kill your engine, and it's really a pain to take in and out because not all the bolt holes line up/seat properly.
If you're looking at doing SCCA autocross/racing stuff, I would avoid doing anything to the car, except tires, until you figure out how you want it to drive. By doing things outside of classing in mind, you'll make your car less competitive, and regret it down the road. Autocross is addicting, and a lot of fun when you're competitive. The mods you're talking about take you into STH territory where those mods won't be competitive at all. STH is about a $7-8k investment if you want to be really competitive, and probably 4-5k if you want to be regionally competitive. I would get a proper alignment, some decent tires, and possibly an adjustable shock first, and then mod from there as necessary for your class/driving style. Honestly, alignment and tires will completely change the car. Take out all the factory rear toe in and front toe in, and suddenly the car will turn telepathically, but this also means you have to slow down when it's wet out
. Rear bar will give you more initial rotation, and may be okay for lower speed stuff, but can lead to unwanted snap oversteer for higher speed stuff. Rear bar should balance the front more than act on its own. Also, if you're not aware, a sway bar can ruin your DD in areas with uneven roads and potholes, but it all depends on your tolerance levels.
