Hey, thanks for all the feedback.
I was planning on dialing back the rear toe (0.1 decimal degrees total, about 1.2mm), but was concerned about the two high-speed brake zones at VIR. The back straight has an uphill which allows you to brake late but it also means that you are turning in at the same time from 136mph. Currently running .14 degrees total rear toe in.
Front straight is downhill and low grip heading into Turn 1. I find the rear getting squirrely going into T1 at VIR as it is.
Then there are two medium speed brake zones that are tricky as you are braking/trailing while using a fair amount of steering input. Heading into T3 turn-in and then the T11-12 Oaktree complex.
I do like how the front of the car reacts with Toe Out and will keep the front toed out. With the IS38 power and additional Vmax, I need to think about my rear toe settings for VIR. The margins for error get really tight as the speeds increase. I’m expecting to be north of 140mph going into the brake zones.
Going to a 265/245 front/rear stagger will be new setup territory for me. The rear tires should heat up better/faster than a 265 square setup and I would likely run the same starting tire pressure’s front to rear with a staggered tire setup.
My current 255 square setup starts with the rear 3psi higher then the fronts. I add a half pound to the RHS for VIR and end up with a square hot tire pressures at the end of a session.
My reason for a staggered tire setup is more around fitment. The Goodyear 3R doesn’t come in a 255. I like the idea of a 265 to tame the power up front. And I know that the 245 will fit in the rear. I can then test fit the 265’s in the rear and figure out a longer term solution for more tire room.
As for additional rear rotation, I will likely increase the rear rebound before going to the stiffer setting on my RSB. I’m already at a higher rear spring rate at the rear - 8k/12k.
Andrew when you are swopping wheels, please post some photos of the Clubsport fuel tube. When you fit the A050’s on the 18x9 et42’s, post some fitment photos. Clearance to the coil overs in the front. Lock to lock clearance to the lower front fender liner. Right rear fuel filler clearance. Overall outer fender clearance.
Its still a couple weeks to my Apex wheels arriving and I need to figure out what my tire options are going to be for this season.
