Quick Update.
Wavetrac is installed
iABED Rear Main Seal
New Sachs SMF
European Audi short shifter
Baun Performance down-pipe/mid-pipe
IS38 with 91-Octane APR high torque tune
Everything appears to be working well and leak free. Will be checking fluids on the trans and VAQ this weekend. Rechecking for any leaks. I’m going to pull an oil sample with 600-miles on the new turbo.
Having tackled all this work myself, my only two concerns were the lack of heat on my first day back on the road. I suspected an air-lock in the cooling system which rectified itself on the second day. The other was a bad clutch judder upon clutch engagement. This was the first time that I had tackled a clutch job myself. Did the work on my drive with axle stands. Long story short, it was just a case of the clutch plate wearing in. Phew!
Had strong clutch plate burnt smell, which had me sweating and thinking I had messed something up. By the second day the judder disappeared and clutch engagement/actuation was back to normal. Put 600-miles on the car. 30mpg on my first tank so pleasantly surprised by the IS38.
RMS was simple with the VW installation tool.
Clutch/Flywheel was simple as well.
Bleeding the release bearing was a multiple bleed process.
IS38 install was tricky because of the tight confines and getting the coolant and oil lines disconnected.
The Wavetrac install had its challenges. Even after purchasing the correct tools. Inexperience and nooby challenges. Getting the one bearing cup out was difficult the other was easy.
I will post a detailed how too for the Wavetrac install.
Busy working on getting the oil cooler installed.
