2017 GTi PP at VIR
Mini7
Charlotte, NC
2017 GTi Sport PP
You have a good split, ride frequency wise, though my calculations do not take into account the CSS swivels. I'd just go up in rate to what ever the next rates you can get are.
Did you get the rear shocks revalved too?
Try 500/700 or 550/750.
Both front and rear were revalved, so I have headroom to go stiffer on the springs.
CSS swivels add a degree of camber. Not sure if that’s because the hole for the strut is offset moving the swivel further outboard, or just the angle at which the hole to receive the strut is different. Not likely to impact the MR by much.
What MR are you using for the front?
xXDavidCXx
2017 GTI SE DSG
I suspect the lower ball joint hole is offset.
I use 0.93 front MR.
xXDavidCXx
2017 GTI SE DSG
If you want to figure it out for yourself.
It's the relationship between A and B. Which is why it's different for every setup/wheel/spacer/hub design.
Mini7
Charlotte, NC
2017 GTi Sport PP
Is your front MR = .93 or .973 as in your diagram below?
**Edit: Diagram above
Mini7
Charlotte, NC
2017 GTi Sport PP
Racingline Oil Cooler install question?
Couple question:
1) Did you remove the front bumper to drill the holes? I managed to get the pilot holes drilled with the bumper on the car but the steel is hard as diamond.
2) Any issues with the supplied filter? Was it effective at filtering out contamination For those who sample their oil?
Mini7
Charlotte, NC
2017 GTi Sport PP
This is generally true, but not for the GTI.
Two things working against you.
1. Ohlins short shock stroke
2. Abysmal camber curve below the stock ride height.
In order to fix number 1 you have to shorten the shock body or run stiffer springs
In order to fix number 2 you have to run stiffer springs to reduce body roll.
Also, comparing rates and tires from anther car is useless unless we can compare ride frequency.
What is the stock ride height for our cars?
Second question is what static camber do you need to run counteract the crappy camber curve?
Mini7
Charlotte, NC
2017 GTi Sport PP
OK, so it took forever to dig up my old notes from when I measured some cars at my local Dealer. Remembering the looks on some faces while I was measuring up cars and taking notes made me smile. Going through Cliff’s build thread and David’s thread, I’ve compiled a FTG ride height list. I don’t think I ever measured my stock suspension because it wasn’t adjustable. Kinda sucks as it would be helpful now with David’s number crunching. I’ve never been fan of lowering cars because it screws up suspension geometry pronto and creates bump steer.
The ride heights in the links you sent, did not help me visualize. Don’t know where the measurement is being taken???
So I come back to FTG measurements which I understand.
So -3.5 front Camber appears to be the number most of us need to shoot for at stock ride height.
The question now is whether we can generate mechanical grip at the front by upping front spring rate vs. loosening the rear axle to get the car to rotate.
This is something I have been chasing on this car. Getting the front end to bite and TURN.
Larger front swaybar will make the car feel very responsive in quick left/right transitions, but spring rate would be better for long sustained cornering. Am I correct in my thinking…????
For Auto-X, I would say that roll is more of a factor then on track? Even with the lower speeds. Granted,with a shitty camber curve, it sucks for both auto-x & track.
STOCK OEM RIDE HEIGHTS - FTG
Nov-192019 GTi SE 225-40-18 = Diameter = 25.1”
FRONT LEFT26.45672FRONT RIGHT26.89683
REAR LEFT26.89683REAR RIGHT26.97685
Nov-192019 Autobahn 225-40-18 = Diameter = 25.1”
FRONT LEFT26.5673FRONT RIGHT26.73679
REAR LEFT26.81681REAR RIGHT26.97685
Nov-192019 R 235-35-19 = Diameter = 25.5”
FRONT LEFT26.34669FRONT RIGHT26660
REAR LEFT26.42671REAR RIGHT26.38670
255-35-18 (25")CLIFF450/600 SPRINGS
FRONT LEFT25.375645FRONT RIGHT25.5648
REAR LEFT25.25641REAR RIGHT25.31643
265-35-18 (25.3")CLIFF450/600 SPRINGS
FRONT LEFT26660FRONT RIGHT26.25667
REAR LEFT26660REAR RIGHT26.125664
265-35-18 (25.3")DAVID400/400 SPRINGS
FRONT LEFT25.625651FRONT RIGHT25.6875652
REAR LEFT26.4375672REAR RIGHT26.5625675
265-35-18 (25.3")DAVID400/650 SPRINGS
FRONT LEFT26660FRONT RIGHT26660
Oct-19FENDER TO GROUND
255-35-18 (25")My Car450/450 SPRINGS
FRONT LEFT26.2665FRONT RIGHT26.6675
REAR LEFT26.89683REAR RIGHT26.6675
Nov-19
FRONT LEFT26.25667FRONT RIGHT26.45672
REAR LEFT26.69678REAR RIGHT26.81681
Sep-20
FRONT LEFT26.2665FRONT RIGHT26.3668
REAR LEFT26.6675REAR RIGHT26.6675
Target Height
255-35-18 (25")My Car450/672 SPRINGS
FRONT LEFT26.3668FRONT RIGHT26.3668
REAR LEFT26.57675REAR RIGHT26.57675
Oct-20
255-40-17 (25.2")My Car450/672 SPRINGS
FRONT LEFT26660FRONT RIGHT26.3668
REAR LEFT27.48698REAR RIGHT27.24692
2317
Dec-20
FRONT LEFT25.94659FRONT RIGHT26.1663
REAR LEFT27.28693REAR RIGHT27.09688
xXDavidCXx
2017 GTI SE DSG
Sways are for turning only, springs are there for both turning and brake/accel.
I'm still not sure how much spring vs front bar is the correct answer, but I do know that a majority of the body control has to come from the springs. There aren't large enough sways to make that big of a difference.
Mini7
Charlotte, NC
2017 GTi Sport PP
Wish Tarrett Engineering made one of there swaybars for the MQB platform. It is slide adjustable and is a great tool to fine tune overall car balance.
Mini7
Charlotte, NC
2017 GTi Sport PP
Hood Vents/Louvres
Decided to add some Verus Engineering Hood Louvres to help relieve the hot air in the engine bay.
Mini7
Charlotte, NC
2017 GTi Sport PP
Brake Cooling Ducts
Looking to use the R transmission cooling duct to feed my brake cooling backing plate. Will need to trim the lower fender liner a little.
Found some compact carbon brake duct funnels that will hopefully allow me to connect the flex hose to the backing plate in a tight space. These attach via pop rivets.
