2017 GTi PP at VIR
Autobahn
Huntington Beach
I know reviews on sites have to be taken with a grain of salt, but there's 5 reviews of them on EuroSports page and all give 5 stars and rave reviews. If you like the stock top hats, really all they're doing is replacing the metal mounts that the strut bolts too and they moved the hole to give more camber and caster. So you probably get a little more deflection than something like the GC camber plates, but sounds like with lowering springs, people are getting -2 camber with them with stock levels of NVH.
I'll let you know when I pick them up, I'm going to wait to make changes to the car until after the autocross season is over.
It’s a solid product and Eurosport is an OG in the VW scene. I track with the owners from time to time in SoCal, good guys, I learned about this product pre-production at Laguna Seca last year. Nothing but good things to say about them and this innovative product. They know suspension.
Mini7
Charlotte, NC
Ohlins R & T with Vorshlag Camber/Caster Plates
So I have been running my Ohlin R&T’s on full soft on the street with my 450lb Swift springs all-round.
Compared to the stock shox, the ride is firm but compliant. The shock does a good job of controlling the spring. The springs do not feel overly stiff.
FYI, my previous setup was stock shocks with 034+ fixed camber plates.
DOT is in the process of repaving the highway between work and home. There is no additional NVH on the new surface with the Vorshlag plates compared to the 034+ fixed camber plates. On the ground concrete where they are preparing to repave; yes no question you can feel the direct connection that strut has with the Vorshlag top mount. Bridge expansion gaps are felt with a solid thud. Is it worse than stock. Yes. Is it super terrible. No. Not in my opinion anyway. It all depends on tolerance levels and what you prioritize. For me this is my daily driver and its my track car at the same time. I value and prioritize handling on track. As such I accept the compromises I have introduced to my car. On concrete highways, its no so much that you feel additional NVH, but have what I can describe as additional tire noise. There are some broken, cracked asphalt roads close to my home. These do transmit some additional noise. As to continual metal on metal noise. None!!! If you hear a knocking sound, you or your shop have not tightened the top nut correctly. That sound only comes from “play” in the system. Potholes, expansion joints, broken roads are more keenly felt for sure. On decent smooth surfaces, friends will not know you are running a full spherical camber plate. Compared to the 034+ camber plates, its hard to say. The Vorshlag plates are marginally noisier. But not by much.
Heck, I am about to install a pendulum mount and anticipate that will bump my NVH levels more than the camber plates.
I am going to increase the rebound settings on the Ohlins to halfway for shits and grins and see what the comfort level is like for my daily commute.
Crild
Florida
This is where I wish I could ride in some of you cars on the street. When you say no discernable NVH I take that with a dumptrucks worth of salt.
Mini7
Charlotte, NC
On good roads. No. And I stand by that.
Don’t cherry pick one statement in isolation.
I’m not claiming no NVH at all.
I’ve had the 034plus camber plates in for a year so I cannot compare to stock suspension because it has been too long for me to be able to make a comparison.
3rdOne
NC
hope you have a great time. Should be nice weather too. I'm planning on running the Charity Laps there next Friday. I'm making plans now for an HPDE next year, maybe some autoX too.
Mini7
Charlotte, NC
Yes, I’m looking forward to the weekend.
Only change has been the addition of the Ohlins R&Ts with 450lb Swift springs
Vorshlag camber/caster plate
SuperPro rear trailing arm bushes
SuperPro lower control arm inner and outer bushes
Should have better wheel control with the Ohlins. I’m interested to see how this setup will ride curbs or whether I will need to adjust my lines.
I’m going to try running higher starting pressures in my NT01’s
I’ve increased camber slightly both front and back to combat shoulder wear. Hopefully these adjustments are in the right direction to get the best out of my tires.
The rear bushing upgrades should help maintain geometry better under track loads.
My next project will be to fabricate some proper brake ducts to extend pad and rotor life.
I will keep you posted.
Mini7
Charlotte, NC
I’m going ease into it.
Get the driver warmed up and reacquainted with the track. Get a feel for the new suspension. Running the first session in the morning in 30-32F temps. It’s going to be an ice rink. Don’t know why they don’t send the instructor group out in the slickest conditions.
So pulled an oil sample this morning. Then checked the oil and was half a quart low. Topped the oil off.
Swopped pads out and bled my brakes at the track. Checked the oil. Now I’m half a quart to high. WTF!
Now I have to drain some oil before my session. Got to get a drain pan in the morning.
Cliff
SF Bay Area
I am surprised they don't. Here in California the ACNA runs 2 instructor groups and they are always the first out on track. It accomplishes a lot: familiarize ourselves with track conditions (and refamiliarize with the track itself) before heading out with a student, the conditions can be marginal with overnight dampness or a sun low on the horizon impairing visibility, and I will usually make sure that one of my students is in my right seat so I can use it as a demo ride.
Blunted_Brick
usa
How was it? Must've been cold AF, early Saturday morning my app said it was 27F.
Trackdaze was cold too, just not as. Haven't run in temps this low (~50s) and wow, so this is what i'm missing by not having a big IC, was indicated 142 mph at end of back straight as compared to 134 back in August.
For shits and grins, i put on PP front brakes with DTC-60s a couple weeks ago. Results were/are mixed, starting with the pads, the damned pads. I ran DTC-60 in the Mk6 and loved them so much i decided i needed to get the PP just to run them. Anyway, Hawk decided they didn't need to install the anti-rattle springs and it was unbearably loud with the clattering of the pads in the carriers. Some drilling, grinding, 4-40 SHCS and springs drilled out from old pads fixed this for a couple hours' work, but wtf hawk. Braking on track and on street is excellent, excellent, excellent, and pad wear on track was as expected (XDS disabled this time!). On the other hand, the 10.3ish pounds of added weight per corner over the non-PP brakes is very noticable, in fact it really sucks and takes away from the "tossability" of the car. I got used to it on track, but in general driving on rough roads the added unsprung mass amplifies every disturbance and makes for a much less pleasant experience.
P.S. Old user name reactivated or whatever, there it is.
Mini7
Charlotte, NC
Yes it was cold. First two sessions were run in 30F. Slick slippery conditions. We all took it relatively easy in the first session of the day. I’m fighting Harry’s on my iPad. It keeps shutting down after the last iOS update. So I haven’t been able to overlay my data on my video. Even with the cold temps, I lost 2mph down the back straight. I vmaxed at 123mph vs 125mph Which is strange. Small difference but with the long straights at VIR it’s still makes a difference.
I only dropped half a second on the new suspension. I took my time building up to speed, but I have to admit that I was not driving at my best. The car felt more stable, more predictable. Better front end bite but still not where I would like it to be.
front shocks were set at 8-clicks from hard. Rears were set at 5-clicks. Because of the issues with Harry’s I have not been able to look at my Harry’s data. I‘m considering running my MPS4S as a reality check for shits and grins. Seeing that my personal best was set on these 300tw tires vs. the NT01’s.
I saw the remnants of a totaled Vette in the paddock from the Track Daze event. The Audi club chief instructor read us the riot act as there were a number of bad wrecks with the Track Daze event.
I’m guessing that you are tuned to vmax at 142mph down the back straight? My friend in a 2015 M3 topped out at 147mph and that car is quick. I was planning on going with a Unitronic tune this week prior to heading back to the track in two weeks. But I do not want to add another variable until I get the suspension dialed in. So I’m likely to wait until next year before adding extra ponies.
Blunted_Brick
usa
Glad you got to run, i was kind of wondering if they'd call off the first sessions.
Yes, i'm APR stage 2 with nothing but the downpipe (no CAI, IC, exhaust, etc) - the exhaust note is mildly obnoxious.
Mini7
Charlotte, NC
So I guesstimated a Stage1+ tune to pick up 10mph down the back straight For a Vmax of 135ish mph. With maybe a 3-4 second improvement in lap times. 142mph is impressive. My drop in Vmax is puzzling me.
Can you elaborate a little more on the effect of running without XDS? So it helped with braking by keeping them cooler....? What was the impact on handling? As XDS is meant to electronically control understeer. So curious on what your turn in was like? You will need to be judicious with acceleration so as not to induce power understeer.
