Hi everyone.
I own a 2016 1.4TSI (150HP) Golf MK7 which had no issues whatsoever ever since I bought it.
About two months ago I started my car and was sitting idle for a few minutes and then the check engine light flashed and the engine sounded rough. I knew it was a misfire so I immediately hooked up VCDS and noticed misfire on cylinder 1. My spark plugs were replaced 2 weeks before that so I suspected it's the ignition coils. I tried to switch between two cylinders but the fault was sporadic and never showed again so I replaced all 4 as a part of a preventive maintenance.
About a week ago after driving to work the engine had a weird hissing noise when sitting idle and after hooking up VCDS again I could see another misfire fault:
The only thing I did not test is the spark plug wires but since the MK7 coils sit on top of the plugs and there are no wires connecting the two... could it be the wires that go into the coil?
Any other things I should check?
Thanks
Thursday,23,September,2021,09:59:12:29935
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.9.0.2 (x64) HEX-V2 CB: 0.4555.4
Data version: 20210903 DS330.0
www.Ross-Tech.com
VIN: WVWZZZAUZGW313595 License Plate:
Mileage: 56276km-34968mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 2B 42 44 52 5F 6C
VIN: WVWZZZAUZGW313595 Mileage: 56276km-34968miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
2B-Steer. Col. Lock -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: Malfunction 0010
Address 01: Engine (J623-CZDA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 027 HD HW: 04E 907 309 BH
Component: R4 1.4l TFS H25 3742
Revision: R7H25--- CVN: 65239CB2
Coding: 0125003223241D083000
Shop #: WSC 65535 000 00000
ASAM Dataset: EV_ECM14TFS01104E906027HD 001007
ROD: EV_ECM14TFS01104E906027HD.rod
VCID: 6D87CD34ED16B0937C7-8038
VINID: 9E69EAAAA465A979C304314914F8A8FD31
Center armrest control head 1:
4 Faults Found:
17158 - Databus
U1123 00 [032] - Received Error Message
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 55862 km
Date: 2021.09.04
Time: 18:42:48
Engine RPM: 1376.50 /min
Normed load value: 15.7 %
Vehicle speed: 0 km/h
Coolant temperature: 32 °C
Intake air temperature: 31 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 11.261 V
Unlearning counter according OBD: 6
Acceleration: 0.000 m/s²
Cruise Control System (CCS): status-Bits 0-7: 0
Drivetrain coordinator: ACC fault status-Bits 0-7: 0
Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 130
Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 0
Drivetrain coordinator: brake fault status-Bits 0-7: 4
Accelerator pedal travel: 0.00 %
7150 - Implausible Data Received from Steering Angle Sensor Module (G85)
U0428 00 [032] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 55862 km
Date: 2021.09.04
Time: 18:42:48
Engine RPM: 1415.00 /min
Normed load value: 16.1 %
Outside temperature: 215 °C
Absolute intake pressure: 41 kPa abs
Engine torque: 16.7 Nm
Fuel level: 14.00 l
Oxygen sensor B1: sensor 1: specified value: 1.0105
Intake camshaft B1 active operating state-Bits 0-7: 0
Overrun cut-off-Bits 0-7: 0
10203 - Random/Multiple Cylinder Misfire Detected
P0300 00 [039] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 56276 km
Date: 2021.09.23
Time: 09:50:24
Engine RPM: 942.50 /min
Normed load value: 14.5 %
Coolant temperature: 93 °C
Intake air temperature: 57 °C
Voltage terminal 30: 13.829 V
Unlearning counter according OBD: 80
Long-term fuel trim bank 1 at idle: -2.53 %
Oxygen control: adaptation value at partial load: bank 1: 0.97009
Short term adaptation of mixture formation bank 1: 0.0 %
Outside temperature: 31 °C
Oxygen sensor test: bank 1: delta lambda: 0.00027
Fuel level: 36.00 l
10594 - Cylinder 4
P0304 00 [039] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 56276 km
Date: 2021.09.23
Time: 09:50:24
Absolute intake pressure: 28 kPa abs
Fuel level: 36.00 l
Oxygen sensor B1: sensor 1: specified value: 1.0000
Readiness: 0000 0000
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 040 H HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 0606
Revision: 00005005 Serial number: CU501604115169 CVN: 110D9D60
Coding: 0014
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_TCMDQ200021 001001
ROD: EV_TCMDQ200021_VW26.rod
VCID: 392F2964E9DEDC33A0F-806C
No fault code found.
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 3Q0 907 379 AA HW: 3Q0 907 379 F
Component: ESC H42 0623
Revision: 00000000 Serial number: 61016000003471
Coding: 01FA6AA12421116F077C060941C82980562488E0608294F30022507AC209
ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036
ROD: EV_Brake1UDSContiMK100IPB_034.rod
VCID: 79AFE964A95E1C33E0F-802C
3 Faults Found:
0297 - Steering angle sensor
B1168 16 [008] - Voltage Too Low
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 252
Mileage: 55862 km
Date: 2021.09.04
Time: 18:42:48
16412 - Display for Tire Pressure Monitoring
C1146 02 [008] - Signal Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 252
Mileage: 55862 km
Date: 2021.09.04
Time: 18:42:58
16413 - Display for Tire Pressure Monitoring
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 252
Mileage: 55862 km
Date: 2021.09.04
Time: 18:42:58
Address 05: Acc/Start Auth. (J518) Labels:| 5Q0-959-435.clb
Part No SW: 5Q0 959 435 A HW: 5Q0 959 435
Component: VWKESSYMQB 021 0604
Revision: 00021000 Serial number: 0400869638
Coding: 030C0C
ASAM Dataset: EV_KessyHellaMQBAB 002011
ROD: EV_KessyHellaMQBAB_002.rod
VCID: 3A2D3668ECD8D72BA95-806E
Address 08: Auto HVAC (J255) Labels:| 5G0-907-044.clb
Part No SW: 5G0 907 044 BC HW: 5G0 907 044 BC
Component: Climatronic H03 1001
Revision: 00001K08
Coding: 00020014100100001005004012101402
ASAM Dataset: EV_ACClimaBHBVW37X 004131
ROD: EV_ACClimaBHBVW37X_004_VW37.rod
VCID: 698FB924D9FEACB310F-803C
Fresh air blower control module (front):
A/C pressure/coolant temperature sensor:
Air quality sensor:
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 CJ HW: 5Q0 937 084 AL
Component: BCM MQBAB M H24 0175
Serial number: 01061610401383
Coding: 00111842C2C102FB0BA44000000403081808000000000000000000000000
ASAM Dataset: EV_BCMMQB 015001
ROD: EV_BCMBOSCH_015.rod
VCID: 025D8E88C4885FEBB15-8056
Wiper motor control module:
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 160401 043 0551
Serial number: 160409034812
Coding: 0E4DFD
Rain/Light Recognition Sensor:
Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S3Y16M04D20H07M54S03
Coding: 90A8DD
Sunroof control module:
Subsystem 3 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.403 H03 0004
Serial number: 0000FST000VUR7N00000
Coding: 181801
1 Fault Found:
197644 - Control Circuit for Fuel Tank Flap
B1263 01 [009] - Electrical Failure
Freeze Frame:
Fault Priority: 4
Fault Frequency: 15
Reset counter: 238
Mileage: 55811 km
Date: 2021.09.03
Time: 11:41:35
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5Q0 919 298 K HW: 5Q0 919 298
Component: PARKHILFE PLA H12 0054
Revision: -------- Serial number: 39431726202033
Coding: 0031161051
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_EPHVA2CAU3700000 003021
ROD: EV_EPHVA2CAU3700000_003.rod
VCID: 47CB5F9CAF2ABAC326B-8012
3 Faults Found:
1113875 - Parking Aid Indicator Lamp
B10FF 13 [008] - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 5
1113619 - Parallel Parking Assistance Indicator Lamp
B10FE 13 [008] - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 5
13637426 - Databus
U1123 00 [008] - Received Error Message
[ESP - ESP_21.ESP_Systemstatus - Fehlerspeicher auslesen]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 252
Mileage: 55862 km
Date: 2021.09.04
Time: 18:42:48
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 D HW: 5Q0 959 655 D
Component: AirbagVW20 015 0388
Serial number: 003F6R1MUFND
Coding: 98CCC000000000005C0000CF004800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002130
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 41DF4184810E84F3E8F-8014
Crash sensor for side airbag: driver side:
Subsystem 1 - Part No SW: ----------- HW: 480 001 504 16
Component: SideSensor_Df 001 0887
Serial number: 35767000000E65608A1Z
Coding: 2D2D2D
Front Passenger's Side Airbag Crash Sensor:
Subsystem 2 - Part No SW: ----------- HW: 480 001 304 16
Component: SideSensor_Pf 001 0887
Serial number: 358670000009D2B8B917
Coding: 2D2D2D
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 3 - Part No SW: ----------- HW: 480 400 904 16
Component: SideSensor_Dr 001 6149
Serial number: 3516502AB1FA34230342
Coding: 2D2D2D
Passenger side rear thorax airbag crash sensor:
Subsystem 4 - Part No SW: ----------- HW: 480 400 904 16
Component: SideSensor_Pr 001 6149
Serial number: 35265029B20414E500F2
Coding: 2D2D2D
Crash sensor for front airbag: driver side:
Subsystem 5 - Part No SW: ----------- HW: 480 400 904 16
Component: FrontSensor_D 001 6149
Serial number: 3556502AF20572856189
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels:| 5Q0-953-549.clb
Part No SW: 5Q0 953 507 HL HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0120
Revision: -------- Serial number: 17041604220609
Coding: 0410
ASAM Dataset: EV_SMLSKLOMQB 020001
ROD: EV_SMLSKLOMQB_018_VW37.rod
VCID: 074B9F9CEFAA7AC3E6B-8052
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 5G1 920 740 A HW: 5G1 920 740 A
Component: KOMBI 202 6420
Coding: 07B519182390080C01083A001400000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009046
ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
VCID: 2411E8107E5CB1DBE39-8070
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 AH HW: 5Q0 907 530 L
Component: GW MQB Mid 211 2246
Revision: -------- Serial number: 06041610802133
Coding: 030100043F085700FB0002481C0F00010001050000000000000000000000
GVL: 01543C0000000600400C00000002C80000000000000000000000000000000000
ASAM Dataset: EV_GatewConti 013020
ROD: EV_GatewConti_013.rod
VCID: 77ABEF5C9F4A0A4396B-8022
Generator:
Multifunction steering wheel control module:
Subsystem 2 - Part No SW: 5G0 959 442 M HW: 5G0 959 442 M Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0103
Serial number: 29180001774290078337
Coding: 29FFFF
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 4139789903
2 Faults Found:
15360512 - Component Protection
U1101 00 [009] - Active
Freeze Frame:
Fault Priority: 4
Fault Frequency: 20
Reset counter: 246
Mileage: 55642 km
Date: 2021.08.28
Time: 12:15:15
Terminal 30 power supply: 13.9 V
Terminal 15: On
8531970 - Quiescent Current
U1406 00 [008] - Too High
[Ruhestrom oberer Grenzwert überschritten]
Freeze Frame:
Fault Priority: 7
Fault Frequency: 37
Reset counter: 33
Mileage: 55647 km
Date: 2021.08.28
Time: 16:47:01
Terminal 30 power supply: 12.7 V
Terminal 15: OFF
Address 2B: Steer. Col. Lock (J764) Labels:* 5Q0-905-861.clb
Part No SW: 5Q0 905 861 A HW: 5Q0 905 861 A
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 16000070365003
Coding: 5D00000000000000
ASAM Dataset: EV_ELVMarquMQB 004111
ROD: EV_ELVMarquMQB.rod
VCID: 34311850CEBC215B739-8060
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 E HW: 5Q0 959 593 B
Component: TSG FS 020 0041
Serial number: 210316ECI10696
Coding: 00151220D000040000001000
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 43D34B8C9B1296E3FA3-8016
Rear Driver Side Door Control Module:
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811 Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_DRV 005 0005
Serial number: 00000000000009751540
Coding: 110000
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 5Q0 909 144 S HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1063
Coding: 0303
ASAM Dataset: EV_SteerAssisMQB 012140
ROD: EV_SteerAssisMQB_012_VW37.rod
VCID: 44D148909E1C91DBC39-8010
2 Faults Found:
12289 - Supply voltage
U1011 00 [008] - Voltage too Low
[Abschaltung wegen zu niedriger Versorgungsspannung Abschaltung aufgrund von Unterspannung (<5.5V für 3ms: KL50=0]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Date: 2000.00.00
Time: 00:00:00
Motor status: 00
System status: Waiting for start request
Supply voltage: 7.00 V
Temperature: 33.0 °C
KFC: 30
KFA: 00 01
Freeze frame conditions: 21
uAdSensI_U1V2Filtered_gdu16: 1.20 V
uAdSensI_U5VFiltered_xdu16: 0.00000 V
uioUdNotFilt_xdu16: 4.98 V
uAdSensI_SwitchedKl30_xdu16: 4.99 V
ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
26885 - Comfort limitation
C10D7 00 [008] - -
[Speicherinkonsistenz im Errorhandler]
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 40
Mileage: 0 km
Motor status: 00
Supply voltage: 0.00 V
Temperature: 80.0 °C
KFC: 69
KFA: 00 05
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 E HW: 5Q0 959 592 B
Component: TSG BFS 020 0041
Serial number: 110416EDA03838
Coding: 00151020DE00040000801000
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 42DD4E8884089FEBF15-8016
Rear Passenger Door Control Module:
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812 Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_PSG 005 0005
Serial number: 00000000000009789778
Coding: 090000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 840 C HW: 3Q0 035 840 C
Component: MU-S--ER 724 0890
Serial number:
Coding: 02730000FF00000051110001000938801F0103C40120010000
Shop #: WSC 00066 790 00405
ASAM Dataset: EV_MUStd4CDELP 001001
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 2B03032C13827EA3223-807E
Display and control head 1 for information electronics:
Subsystem 1 - Part No SW: 5G6 919 605 A HW: 5G6 919 605 A
Component: ABT_Std-2 H52 8130
Serial number: VWZ6ZJV1626432
3 Faults Found:
1555 - Check Software Version Management
B201A 00 [009] - -
[Check software version management]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 198
Mileage: 55642 km
Date: 2021.08.28
Time: 12:15:15
Voltage terminal 30: 13.8 V
Status_Software_Version_Management-module_name: C
15360256 - Component Protection
[Anti-theft protection - component protection active (0xEA6100)]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 198
Mileage: 55642 km
Date: 2021.08.28
Time: 12:15:15
1637 - Interface for External Media
U11B8 00 [008] - No Communications
[USB - communication error]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 12
Mileage: 55863 km
Date: 2021.09.04
Time: 11:07:10
Voltage terminal 30: 13.9 V
Interface for external media: status-Status: Open circuit
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb
Part No SW: 5Q0 980 556 B HW: 5Q0 980 556 B
Component: RVC Compact H18 0231
Coding: 01840201E2002017000040
ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
ROD: EV_CamSysRVRVCPANAMQBAB.rod
1 Fault Found:
13705478 - Databus
U1121 00 [009] - Missing Message
[message Parkhilfe_01 not received]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 198
Mileage: 55642 km
Date: 2021.08.28
Time: 12:15:15
passive
End----(Elapsed Time: 01:40, VBatt start/end: 13.9V/13.9V. VIgn 0.0V)------
Thanks
