2014 GTD intermittent long crank
xllusive
Ireland
2014 GTD
Hi, recently purchased a 2014 GTD and ive been having a long crank issue after the car sits for say over 6 hours, the battery has been changed and coded in and the only other thing I have noticed is I am unable to to hear my lift pump unless I activate it using VCDS, I presume it should be audible on turn of the key. Any help would be much appreciated. The car acts exactly how it should after starting up
Thanks
xllusive
Ireland
2014 GTD
I had a good read of it but im just curious if the lift pump should be audible when turning key because I can hear it clear as day when priming using vcds but nothing when I turn key
