200tw tires for Track use
DerHase
Hampton Roads, VA
2019 GTI Rabbit
Meh, keep running it but keep an eye on it. In my experience you continue to wear it and then it disappears. Has happened on several of mine and friends' sets. Shine a light down in the crack, spread it lightly and check for cords. If none it's fine.
Absolutely nothing like the delaminating V720 fiasco where you could fit your entire hand under the tread of the tire once it separates.
SouthFL_Mk7.5
South Florida
2019 GTI S
I had a set of V720’s! Awful.
krs
Las Vegas, NV
MKVIIS R
Y
Yes. I went looking for evidence of it on my set before I put the tires away and it seems that I may have found it.
Welcome to 660’s.
Try the V730 as an alternative.
Yeah, mine have worn down to slicks with no weird wear issues or delamination. That's with a track day in 93+ deg heat and 7 autocrosses with 2 to 3 drivers every event.
krs
Las Vegas, NV
MKVIIS R
Falken got back to me an offered a pro-rated return on the RT660s for the tread issue. They actually want all 4 tires back to investigate what's going on. When I was at Pocono 2 others who ran RT660s had this same failure. One of our buddy's does gridlife and had an RT660 delaminate completely at speed. Not sure if I'll go back to R888Rs or try the Conti. Also looking at my BBK 17x9 options; 17x8s are just a little bit too narrow for a 245/40R17 in my opinion.
I really hope Falken solves this tread issue on the RT660 because it was an excellent tire otherwise.
Tirerack told me to pound sand.
jmblur
Massachusetts
2017 Golf R
We'll see if a proper heat cycle treatment helps with the grooving issue. Not holding my breath!
Now to decide if I'm installing my wheels at home and driving the 90 miles round trip to autox like usual, or hauling everything up to switch tires at the event. Leaning towards slightly less life, much more convenience and more sleep in the morning!
R Golf
Lenox, MA
I never found it worth it to swap tires at track. I do HPDE ,not autoX, but I think the correlation would be similar.
I've been tracking since 1998 with a variety of cars and tires (Falken 660's for the last couple of years) . A typical year for me is 10-12 track days. The only data that correlates to tire life comes down to the number of track days on them with virtually zero correlation to street miles driven.
DerHase
Hampton Roads, VA
2019 GTI Rabbit
Yep. I've done an entire season of autocross on RE71Rs + 18,000 street miles (on my Mazda2 several years ago). The main thing for me is the risk of road hazard like picking up a nail or something on the way to an event. I normally put whatever wheels/tires I think I'll want based on the weather prediction, and pack the second set with me just in case something changes. I used to have RT660s for track, and Conti ECS for rain on track/daily which worked out well. If it was crappy weather I didn't have to swap tires back in the rain.
geokilla
Toronto, Ontario, Canada
2018 VW GTI DSG
I like to run street tires for street driving, and then day before, swap to track tires for track day. The louder tire noise is super annoying for daily driving and the 15% fuel economy hit sucks, especially when premium is $2/L. Though if I had only 2 weeks in between a track day, I'd probably just suck it up and run the track tires cus I'm too lazy to swap all the time.
krs
Las Vegas, NV
MKVIIS R
I swap mine. Trips to California are about 300 miles round trip, plus I daily my car otherwise.
I don’t mind the swapping, gives me a chance to rotate things, check brakes and suspension components.
jmblur
Massachusetts
2017 Golf R
Yeah I always swap the night before an event. Good opportunity to adjust the suspension too.
I used to swap at the track, but a jack accident stopped that. Didn't have a decent place to swap, tried on crappy asphalt, jack wheels for stuck in a rut and car came off jack on way up. Not cool.
Easier to do in my garage. Only caveat is I've had to drive home in heavy rain on what are basically slicks.
xXDavidCXx
AZ
2017 GTI SE DSG
