2 Year Service
btscott
Bay Area
I just did my second oil change. I do them myself. Only 5800 miles after 2 years. Other than oil change any other recommendations to service with only 5800 miles on the car? Thanks.
Golfs everyday
Mine is a 2017 bought new in 2017, currently at about 6300 miles. Besides a thorough visual inspection, oil and filter change is all she needs unless your brakes are mushy for some reason. I would also check your tire pressure if you haven't done so already.
OldVWFan
NW Arkansas
17 GTI Sport
2 years old, brake fluid absorbs water vapor, most places recommend changing at this time and you will feel a difference.
Golfs everyday
I suppose it could, but I've yet to experience this in real world on my low milage cars. I've bought over 30 new cars in my life time and the ones I followed the 2yr brake fluid change (low milage cars) had zero difference after the job. So I only do brake flush when they actually feel mushy or discoloration in the reservoir. I do my own maintenance and have the proper equipment to do it correctly.
But this is just how I do it, others may be intrigued to change it and they should if it makes sense to them.
OldVWFan
NW Arkansas
17 GTI Sport
Same here as to doing my own maintenance now for about 50 years and have owned many cars and motorcycles and still never go more than two years on doing a full brake system flush no matter what the mileage. Mileage is not the key here but time as the fluid does absorb water vapor as it this weakened over time.
KevinC
Cochise County, AZ
'19 Golf R, '08 Z4MC
This, of course, is the correct answer. Ignore that idiotic advice above to wait for a "mushy" pedal or discoloration of the fluid. Possibly the worst advice ever dispensed on this board, and that would be quite an accomplishment.
Yep definitely a good decision to finally check the air pressure in the tires after two years. ?
Golfs everyday
You folks do what you need to do, I just do the brakes when they feel they lost the sharpness in initial response. I've had cars that needed brake flush within a year after a fast canyon run. Hardly milage or age based. 2yrs/milage interval is just a guide. If you're worried you can just bleed the brakes too. That'll give you a visual reference if you're not sure by pedal feel.
tmw2442
SC
Mk7 R
