Exactly why I bought the hpfp. Less than 200$ fitted...only took 30min or so, I had planned everything. Wiring, bolts, new seal, special cloth fabric tape (Tesa 51026 https://www.tesa.com/en/industry/tesa-51026.html ) etc.MPI is dated technology. The only reason cars make the power they do today is because of DI. Adding more to the MPI or adding it to a car that doesn’t have it is just an inexpensive option vs upgrading the DI. So the cost is the only reason guys do it. A used 2.0 hpfp and vacuum pump is only around $100-150 usd. It is not just allowing more fuel, it’s increasing the pressure by 60+bar. That swap alone on an is20 1.8 netted over 20whp and 30wtq average and peak over the stock hpfp. On larger turbos and higher horsepower cars it’s probably more. So yeah you can get more fueling and power with mpi, but you are leaving power on the table for such a simple upgrade. No other hardware adds that much power per dollar. So yes to mpi and more ethanol, but definitely yes to the 2.0 hpfp as well.
https://www.ebay.com/itm/323830774828
You can see I made a "Y" harness so I can swap between pumps
ps. Stock 1.8 hpfp can go up to 200bar (2900psi) but its not working properly at that rate. (its rated at 180bar)
