tigeo
- Richmond, VA area
Correct - GSW is 60mm, R is 65mm.Think I’d see much power loss? Probably not too much I’d think
Yup. Let me know what you end up with. I maaaaay put a R pipe in and go back to a more OEM+ type setup.. maybe..Yeah I have one on the IE as is. Assuming I’ll need a different Od
R pipe has 2 cats so there will be a flow loss. Will it matter at like.. 25 psi? Probably not a lot. Will it matter at 29 or 30 psi? Probably a bit.Think I’d see much power loss? Probably not too much I’d think
I still don't see how this would really cause any drama.Probably R pipe. Gonna just make this as easy as possible, after I swap these plugs and coils
Put....the plugs..... away. There's nothing to be concerned about. Let the tuner do their job. It's clearly a base file since the initial knock correction table hasn't been touched. It's very conservative.
I want Diggs to be right very badly right nowYeah plug looks good.
He probably is. Just something easy to do to swap them and re-log b/c EQT is likely going to wonder/ask about it. Just strange to -5 on one cylinder.I want Diggs to be right very badly right now
Ironically I swapped the plugs and the idle seemed a little better. Maybe I did an accidental good lolHe probably is. Just something easy to do to swap them and re-log b/c EQT is likely going to wonder/ask about it. Just strange to -5 on one cylinder.
