17" Winter Setup on Michelin X-Ice (fits R brakes)
theblackgt
VW MK7 GTI / BMW F07
Sport Edition F7s on Michelin X-Ice, wheels specs below. Used for only one season, ~9.5/32 tread left. These will fit R brakes, as I run MK5 R32 brakes which are larger and clear with no issue.
Local pickup preferred, can ship possibly. Zip code 07083 (NJ).
Total setup was around $1600 all in. Asking $690.
Mk_GTI
Hellinois
2018 Golf R
Had this exact setup. Great tires for snow!
Confirming it will fit over R brakes. Tight fit, but it will clear. I recommend placing wheel weights near the inner rim for extra clearance and using plastic centering rings.
dynamisoz
USA NJ
hi.. whats the center bore size?.. does it come with centering ring if its not 57.1
Mk_GTI
Hellinois
2018 Golf R
Requires centering rings to fit a VW hub. Highly recommend buying plastic ones instead of metal if centering rings aren't included. Otherwise, make sure to clean the hub surface very well before and after using.
theblackgt
Correct it requires hub rings and they're included, they are metal too.
