inc55
- Chandler, AZ
True But the stock Battery dies at 1 to 2 years.
My 2015 battery lasted for 3.5 years. Finally died once I moved to the Oven State (Arizona). I got a bigger replacement and coding took 2 mins.
It will work but the car is going to be overcharging the battery.
Really should get it coded. When I replaced mine with a 48 AGM from O’Rileys the “old” coding was for a BCM battery.Well the battery I put in back in 2019 died already. It looks like it's leaking, I never got it coded. I wonder if it was overcharging itself and died a premature death? I'm going to put a new one in, can you do the coding with OBDeleven?
Anyone have specific instructions for coding a battery? I’m going to mark this for future reference.Really should get it coded. When I replaced mine with a 48 AGM from O’Rileys the “old” coding was for a BCM battery.
StealthGTI with OBD11. Give a like!Anyone have specific instructions for coding a battery? I’m going to mark this for future reference.
Well you might want to check what your battery is currently coded to ensure you have the correct code for your current battery. I "think" my battery from the dealership was a BCM; when I put in the new battery I bought a AGM, and only found out the coding because I went to change it. Just sayin.Did some more reading and seeing that unless you have start/stop functionality you don't need to re-code.
Check to see whether there's a battery control module on the negative terminal.Did some more reading and seeing that unless you have start/stop functionality you don't need to re-code.
