034 Motorsports Dogbone Mount Insert
mk4_337
Houston
I read through the forums and couldn't find a direct answer but is Version 1 having no issues compared to Version 2? Sorry if this was answered already
I have a 2016 Golf R with Version 1 and I just want to make sure it is safe to go through with my purchase :D
I appreciate all the help!
surfwagon
San Marcos, CA
I'm using version 1 without any issues.
rsafier
Ohio
I just installed the version 1 mount earlier today, and then took an hour long ride. Zero issues, took longer to jack my car up in the garage than install.
Chronic
I'm using version 1 no issues
reallypeacedoff
I think there is some confusion here.
Version 1 and Version 2 are different. You need to get under the car to see which version you should buy.
I do know that they have revised both versions slightly too. I have Version 2 OG version and no problems here. The Revision B looks a little bulkier.
Finglonga
What's inferior with the stock one as fitted from VW? And where does it fit?
Thanks.
There isn't one that is the problem, the insert fills the void in the dog-bone bush to stop excess movement the causes the wheel to tramp/hop. It is under the car at the rear of the engine gearbox fixing it to the body.
Chronic
This is what version 1 looks like
And this is what the insert looks like when you find out which one you have
Version 1
And this is it installed
You will need to look under car to see which one you have as this is version 1
Chronic
And this is what version 2 looks like
And this is what insert looks like
mk4_337
Houston
I have Version 1, I checked under the car yesterday :D I'll be purchasing it tonight and reviewing in here how I like it! Thanks everyone!
Mr Golf R
Florida
Thanks. I have the DSG and 4 motion and have experienced no wheel hop. When launching at 4k RPM'S, car just squats and takes off.
