bentin
- Austin, TX
- 23 Golf R - 3 Pedals
Chock full of win.
How about the 4-pot Mk2 TTRS brakes? Any plans to find local 8J/8S/8V owners to test out the larger audi brake setups?We have yet to test the 8-pot 370mm TTRS brakes with the 18x9" ET42, so we cannot confirm if they will be able to clear without spacers. However, if you happen to have a .PDF brake template for that specific caliper/rotor, feel free to send it over in a PM and I can check the clearances with our engineering team.
To follow back on the 8-pot kit, we have confirmed fitment with the 18x9" ET42 to clear the factory 8-pot 370mm TTRS brakes without any need for spacers. With that said, the 4-pot MK2 TTRS brakes should be able to clear the 18x9" ET42 just fine, as well.How about the 4-pot Mk2 TTRS brakes? Any plans to find local 8J/8S/8V owners to test out the larger audi brake setups?
Great photos!The 18x9 first use, with yokohama 250/640, at Interlagos. It was really nice to test the whells at this track!
Thank you!Great photos!
Did you have any problems with the tires rubbing? Your car appears to be lowered?
Any issues with tire clearance on the right rear, with the petrol fill tube?
Probably lower ride and 250 slick tireThank you for that information. I have Ohlins suspension and I can run 255-35-18 front and rear. It’s tight but no rubbing. The right rear is very tight. Slicks tend to run wider than radial tires. Other than the front clearance for the suspension. Do you think the rubbing in the front was because of the lower ride height?
I went through a decent amount of this thread but didn't find the answer I was looking for. I am ordering a set of these wheels this weekend but having a hard time deciding between 17 or 18 size. I would prefer the 17 but unsure it if will fit my VWR 360mm BBK (link). Since I just picked up the car a couple months ago and was unsure of the brake kit it had installed till today when I popped off the wheel to measure rotors and find part numbers. Looked for a template but didn't find anything on the web except the new versions of VWR's BBK
Anyone running the 17's with this older VWR 360mm BBK?
Yeah I did. They did not have that specific one tested and I can't find the template anywhere online. So looks like I am going to order the 18's to be safe.Did you reach out to Apex? They have measured for a lot of brakes
Nothing I can share just yet, as our engineering team is still finalizing a few changes to ensure we are able to clear all of the important aftermarket BBKs that the SM-10s clear. I will be sure to update the community regarding forged VW wheels as soon as I am able to!Any glimpse of the forged design? I may have to take you up on this deal though.
