Nice! I also have a 1.8t
Just got apr on it yesterday. Would you be willing to help me out with some of those vag com mods..I'd like the 4 blinks, mirrors down in reverse if possible.
Keep up the good work. Can't wait to hear and see some more
Set comfort turn signal to 4 blinks
1. Click SELECT, under the "Select Control Module" section.
2. Click 09-CENT. ELECT.
3. Click SECURITY ACCESS-16
4. Enter code: 31347
5. Click ADAPTATION-10
6. From the drop-down list, select: (2) - Turn Signal Controls - Komfortblinken Blinkzykien
7. Enter a new value for number of blinks (e.g.: 4)
8. Save.
9. IMPORTANT: After completing the VAG-COM coding portion to this mod, turn your ignition off, then back on. Go to the Car menu > Settings > Factory Defaults, and reset LIGHTING SETTINGS to factory defaults in order to apply the new comfort turn signal value.
Disable audible lock/unlock confirmation
6. Look for the following:
(1)-Acknowledgement Signals -Akustische Rueckmeldung entriegen (Un-lock audible feedback)
(2)-Acknowledgement Signals -Akustische Rueckmeldung verriegeln (Lock audible feedback)
7. Set to on or off.
8. To enable the audible lock/unlock option in the Car menu:
(7)-Acknowledgement Signals -Menuesteuerung akustische Rueckmeldung (audible lock menu option)
9. Set to on.
10. Save.
Enable gauge sweep
2. Click 17-INSTRUMENTS
3. Click CODING-07
4. Select FUNCTION 10
5. Select BYTE 1
6. Enable bit 0
7. Click on "Do it!" to save the change.
Disable seatbelt warning chime
3. Click CODING-07
5. Select DISABLE SEATBELT WARNING [Gurtwarner Deaktivieren]
6. Change value to YES.
Enable battery state of charge (SOC) in MFD
3. Scroll down to "Battery Charge"
4. Change the value to ACTIVE.
5. Save.
Disable bulb-out error for license plate lights (usually after LED license plate bulb install)
6. Select "Leuchte25KZL HA59-load type 25"
7. Change values to LED GENERAL; VALUE: 43
8. Select "Leuchte25KZL HA59 dimming AB-25"
9. Change value to 127.
10. Restart car to apply change.
Enable amount of fuel since last full-up in MFD
3. Select LONG CODING.
4. Select FUNCTION 07
5. Select to Byte 10
6. Enable bit 4
7. Click on "Do it!" to save changes.
Change MFD background to carbon fiber look (THANKS RACINGLINE)
5. Select "Display Representation [Displaydarstellung]
6. Change value to "Variant 2" (default value: Variant 1)
7. Save.
Disable/enable Daytime Running Lights using Discover Media screen (mkVII)
The following coding is used:
1 Select 09-Cent. Elect.
2.Select Security Access-16
3. Enter Code 31347
4. click Do it! tab
5. Select Adaptation-10
6. From pull-down channel list, select (2)-Daytime Running Lights- Tagfahrlicht Aktivierung durch BAP oder Bedienfolge möglich
7. Enter New value = active (default stored value = "not active").
Click Do it! .
Click Add to log to record a copy of the change report .
Click Go Back and exit the VCDS software
Using the function
1. Select Car from the buttons on the side of the media screen. Then press Setup (on the bottom RHS)
2. Select Light
3. Enable the "tick" on Daytime Running Light (tick-on DRLs on, tick-off DRLs off
MIRROR DOWN IN REVERSE
Yes.....Just remember to keep the mirror switch on the passenger setting for it to work.
52 Passenger door
07 coding
Byte 4
Enable bit 2 and 3
THEN
09 Central Electronics
31347
Adaptations
17-Access control 2 Spiegelabsenkung bei Rueckwaertsfahrt (change to “active”)
THEN
(22) Access control 2-Menuesteuerung Spiegelabsenkung (change to “active”) this puts the option in the menu screen.
MIRROR DOWN VIA KEY FOB
https://docs.google.com/file/d/0B0R_NG46t4glTUlLb2xwX0R4QUk/edit?pli=1
These are the mods I had done, didnt have a problem with any of them. Very straight forward once you open up VCDS
