dwvw
- Red Deer Alberta Canada
vdubpwr, have you got any fender to ground measurements yet? Once I am happy with my ride height and get an alignment I'll post up.
The tread patch doesn't change that much with an oversized wheel though, does it? The stretch doesn't stretch the contact patch, just increases the angle of the sidewall?
I have Michelin PSS 235/35r19's on Neuspeed 19x9 RSe10's and there is just the slightest hint of stretch. I wouldn't want to go any smaller on the width of the tire or wider on the wheel unless I was doing a bagged car for "stance".
Pouria,
I asked some of the MK7 guys if the MK7s rub with an ET35. Their responses are a few posts above this. The general consensus is that the rears are no problem in an ET35, but the fronts do poke a little bit.
First off fix your specs. Your wheels are not 18.5". They are most likely 18x8.5 if I had to guess. Wheels either clear or they don't. If they turn and don't scrape then you're fine. The reason for this is because CCW uses the same size face for a 17" wheel and an 18" wheel. The only difference is the lip and barrel.
