SixSpeeder
- Forum, Doe.com
I'm interested in buying one of these, can anyone tell me a reason not to? What are your reviews and impressions on this upgrade?
-Rated to Hold 30lbs of Boost Sharper throttle response
-Retains the factory solenoid coil for seamless integration
-Replaces plastic valve parts with metal for reliability and strength on chipped engines
-Direct-fit replacement with GFB’s TMS benefits
-Exclusive “pilot-actuated” valve mechanism for rapid response at high boost -Anodized finish for long-lasting performance and looks
-No need for frequent rebuilding or a “rebuild kit” as is common with some brands. The dv+ brass piston is supported by a hard anodised bore -
See more at: http://www.moddedeuros.com/products...lve-2-0t-fsi-tsi-engines#sthash.Hc4DiiKx.dpuf
