I replaced the incandescent light from inside the trunk by a Philips LED light - Festoon 6000k 43mm.
However the Led light is never completely turned off with the trunk closed.
Anyone know what I should do to erase it completely? Some modification via VAG?
Which LED bulb should I use to get totally off when door closed bags?
Thank you
Thank you
