I know the guy who knows but I don't know his name on the forums lol
DV52?
I wish I could say that I felt the same after I had my Wavetrac installed. I went to a new track this weekend, so I don't have a good before and after comparison, but frankly, I can't say I felt anything significantly different. I had the ESC on and did notice the light flash once. I never felt the ESC working, so I assume it wasn't particularly active. There wasn't any wheel spinning, but the car still understeers under power, even with all my other suspension mods. I was hoping the LSD would reduce that tendency. Can't honestly say that it did.
Lastly, an upgraded rear sway bar such as the 034 will help the most with understeer. Judging by your sig, looks like you have everything but that, which makes the biggest difference on the car, suspension-wise!
nah he has Eurocode front and rear sways. Perhaps it's that beefy, at nearly 29mm, front sway?
What are your current camber and toe settings? What tire pressures did you run?I wish I could say that I felt the same after I had my Wavetrac installed. I went to a new track this weekend, so I don't have a good before and after comparison, but frankly, I can't say I felt anything significantly different.....
I have read that stiffening the FSB does have a negative effect in regards to understeer. I know this is specifically why 034 decided to make their RSB to be used with the stock FSB, and I think it feels amazing.
Not trying to attack you here, I'm just sayin
Thanks for that article man!Yes this is true. I hear there is a way in VAGCOM to increase clamping force.
Btw -- I am the author
Great article. I'm in for the VAGCOM coding...Yes this is true. I hear there is a way in VAGCOM to increase clamping force.
Not feeling attacked. Probably driver fail!
thanks-2 front, -1.3 rear camber
0 toe in front and back
34psi cold front and back
Most popular fail. Do you know about dynamic weight transfer?Not feeling attacked. Probably driver fail!
