VCDS - Enable Display of Gear while in D & S
quailallstar
WOB DJ496
Florida & our Nation's Capital
MY19 MK7.5 GTI Bunny
With the help of VCDS, I was able to make the current gear show up while in D & S modes on my MK7 NAR Golf wagon! ;)
Code:
Address 02: Auto Trans (J217)       Labels: 09G-927-749-V2.clb
   Part No SW: 09G 927 749 AP    HW: 09G 927 749 AP
   Component: AISIN AG6 G3  129 2943
   Coding: 010100000C000000000000000000000000000000
   Shop #: WSC 00066 790 00060
   ASAM Dataset: EV_TCMAQ250031 002009
   ROD: EV_TCMAQ250031_002_VW25.rod
   VCID: 0717E50FBEB4D67F80-8052
No fault code found.
Original:
010200000C000000000000000000000000000000
New:
D1-6 / S1-6 now show up 100% of the time. Not sure if any driving characteristics like shift points are impacted, but will report back tomorrow after time spent driving.
Crud_muffin
US
e-Golf
Wow! Thought this was exclusive to TCU tunes. I wonder if the coding works on all Golf variants.
toledospeed
3rd rock
Awesomeness! Will try this soon, was just wishing this could be done a couple days ago.
NeedSleep
USA
2016 Golf R DSG
This is awesome! Will this work in a GTI or is it a different TCU?
I checked my car, and the GTI DSG only has 2 Bytes ("0014") in the long code compared to what the OP has, so their code isn't applicable to us.
Sent from my SM-G930T using Tapatalk
TJN
Palm Coast, FL
2017 Alltrack S
For those who have OBDII, go to module 02, select Long Coding, Select Byte 1. You should see Bit 1 selected. Uncheck Bit 1 and select Bit 0. The code string should now match to the OP. Double check that before accepting the coding.
Sent from my SAMSUNG-SM-G890A using Tapatalk
Old Guys Rule
Florida
On scanning, that's what my 2016 R reports too. I'll need to see what long coding shows.
toledospeed
3rd rock
Confirmed working on my 2015 TSI. Thanks again!
