Hammersticks
- Bay Area, CA
- Car(s)
- '16 GTI, '18 e-Golf
I get this question from time to time based on the spring install reference guide I put out so I wanted to bring this up here and I'll add the link to the other thread.
I have typically done what the install instructions say to do on different applications (cut or not), but I know not all instructions include that info leaving people sometimes scratching their heads as they are neck deep in the install.
H&R offers this information on how bump stops impact spring rates: http://www.hrsprings.com/technical/spring-rate-101
Their general guidance is NOT to cut unless instructed to do so; however, if you watch the Emmanuel Design video they trim them when installing their ED springs which aren't ultra low themselves. I have also heard to trim front and rear regardless if you are lowering. Specifically: trim 50-75% of the TOP coil on the rears and 1/4-1/2" of the TOP coil on the fronts...at least on the GTI. (assume about the same for golf variations)
Back when I did my initial lowering install of neuspeed sports, I trimmed them based on the feedback above, despite the lack of instructions from Neuspeed to do so.
Cutting the bump stops seemed to work fine with the Neuspeed sports. I only had the setup for about 5k miles so TBD if there would be any long-term impacts.
The only other thing is that not all shocks/dampers require bump stops. For example, the Bilstein B8 fronts have their own internal ones, so read up on what you have before you dig into it.
So, what did you do for yours?
Cheers.
Cheers.
