Will be tracking the R often. Not competitively as I race a C6 competitively. but often.
Going to flush brake fluid and replace with SRF. can you activate the ABS with OBD eleven or would I need to take to a dealer or someone with the right computer?
The R brakes seem very good on the street however do seem to be heavily front biased. I plan on running carbotech X10 or 12's in front with stock or similar rotors. will also put on some stainless lines. In searching it seems 50/50 on whether to also change rears or just run them stock. What are people that are actively tracking suggest? Although the 10's or 12's don't have massive bite I am concerned that running either with stock rears will unbalance the car when aggressive braking is applied. The tracks that I will run are hard on brakes as am I. I have no issues with swapping both for track use.
This will be my first mod until I get use to the car and will then consider other suspension mods if required.
