Guys, I really need some guidance here.
Over the summer I had an issue where the turbo wind-up would sputter under hard acceleration. I was running a Neuspeed power module w/ Injun intake back then.
Given that it was a hot summer, I summed it up to heat saturation and more or less dealt with it, avoided heavy acceleration.
Fast forward to today; it's mid-50's (F), Neuspeed module is gone. I'm running Eurodyne's Stage 1.5 93 Octane. Same problem under heavy acceleration. If I ease up on the pedal a bit, it spools no problem and sounds normal (as well as puts out the power it should), but if I lean on it harder, I don't get more power and the turbo sounds like it's repeating the first 1-2 seconds of trying to wind up, over and over again. (If that makes any sense)
I'm not getting any codes.
Also, I ruled out shitty fuel as the issue; I filled up on Shell 93 and put a whole 32oz can of Torco in there, so octane rating is definitely not the issue.
Any help would be really appreciated...
