Peppy2's build
peppy2
east coast
I purchased my Mk7 last in June. Since then, it has been transformed into a car that I love to drive. In my opinion, the best upgrade I feel that was worth it was the brakes. My driving consists of 90% highway in areas where 90% of other drivers have no idea what a turn signal is or how to activate it. The other reason is the gti isn't a "slow car". If I wanted to drive slow, I would of gotten a regular golf. I use to suffer from brake pedal shudder when coming down from higher speeds but now it's smooth and effortless. Even now that I just did the 38 upgrade, the BBK was money well spent. Most will be happy with the stock setup but I guess it all depends on what you do with the car.
Engine:
IS38 turbo- A+ upgrade
APR TCU tune- A+ upgrade
APR ECU tune- A+ Upgrade
Denso IKH01-24 Racing Plugs- Big difference than what APR recommended. Fouled the IKH0-24's in 5k..
APR intercooler- Noticeable in the summer months. No heatsoak with back to back pulls
APR intake- Questionable if it was worth it..but it looks pretty..
APR catch can- It does it job for the most part.
APR boost tap- Clean look if you are doing a boost gauge
APR boost hoses- Hard to tell if it helps with airflow and power gains
APR down pipe- Must have A+ upgrade
Forge intake hose- Need one for the intake
Neuspeed HI FLO discharge pipe-Hard to tell if it helps with airflow and power gains
Neuspeed HI-FLO charge pipe-Hard to tell if it helps with airflow and power gains
CTS muffler delete-Larger diameter than APR's. I sure it helps with flow.
Neuspeed dogbone insert- Definitely made a difference with the slop
Suspension:
Integrated engineering camber kit- POS
Vogtland coilovers-Excellent price and does its job
Neuspeed Front and Rear swaybars- Should of just tried the rear first.
Superpro end links- Neuspeed endlinks suck. Superpro MUCH better.
Brakes:
Stoptech ST-40 4 piston/355mm 2 piece slotted rotors- Best upgrade. Wish I could test out a 6 piston though..
Stainless Steel brake lines
Wheels:
Summer set..
Neuspeed RSE10 18x9
Extreme contact DW's 235/40/18
42 Draft Designs 18/10mm spacers for stock wheels
Winter set..
Enkei TY-5 19x8.5
Extreme Contact DWS 235/35/19
42 Draft Designs 5MM spacer
Exhaust:
AWE tuning Touring exhaust/ Chrome tips- Mellow until you lay into it.
AWE Track Test Pipe- Rowdy! Love scaring people in the tunnels and underpasses. Slight drone..
Interior:
3M Crystalline 40% tint on sides and rear /90% on windshield- Crazy how this stuff works! (wizardry black magic stuff) Expensive but worth it.
South Bend vent boost gauge-Ehh.. more for looks..
Euroswitch with rear fog wiring- Easy upgrade and functional if you're going to do euro tails or change thing in VCDS for lighting
Weathertech mats/cargo mat-Must have to keep your car interior clean
OEM GTI rear seat cover-Same as above(especially if you have a dog..)
Paddle extensions-More functional than I thought.
Exterior:
Gloss Black emblems- So stealthy..oooh...
Tinted aspherical mirrors- Helped with blind spots
OEM Dark Cherry LED taillights- Definitely not needed but makes the look of the car amazing.
VCDS Tweaks:
Window up/down- Highly recommended VCDS tweak
Seatbelt chime delete- Deleted only because of city block driving.
Soundakator delete-Obviously a must if you have exhaust work..
Windshield washer level indicator delete.- Had to..it was annoying..
peppy2
east coast
Single 12TW3 Truck PowerWedge, Sealed, 2 Ω
Monoblock Class D Subwoofer Amplifier, 500 W
Was going to get a 10W7 but the sales guy said it would of been a whole lot of overkill for the car. He said that this setup was plenty enough...
deanmarr
I purchased my Mk7 last year in June. Since then, it has been transformed into a car that I love to drive. In my opinion, the best upgrade I feel that was worth it was the brakes. My driving consists of 90% highway in areas where 90% of other drivers have no idea what a turn signal is or how to activate it. The other reason is the gti isn't a "slow car". If I wanted to drive slow, I would of gotten a regular golf. I use to suffer from brake pedal shudder when coming down from higher speeds but now it's smooth and effortless. Even now that I just did the 38 upgrade, the BBK was money well spent. Most will be happy with the stock setup but I guess it all depends on what you do with the car.
Engine:
IS38 turbo
APR TCU tune
APR ECU tune
APR intercooler
APR intake
APR catch can
APR boost tap
APR boost hoses
APR down pipe
Forge intake hose
CTS muffler delete
Suspension:
Vogtland coilovers
Superpro end links
Brakes:
Wheels:
Summer set..
Neuspeed RSE10 18x9
Winter set..
Enkei 19x8.5
Extreme Contact DWS 325/35/19
Exhaust:
Interior:
Paddle extensions
Exterior:
Gloss Black emblems
tinted aspherical mirrors
VCDS Tweaks:
Window up/down
soundakator delete
windshield washer level indicator delete
Damn That's an impressive build.
MonkeyMD
Hilarious. :(
Jk. Very nice ride.
I do think your winter tires are too wide. Do they rub. ;)
And why not keep the dws year round. Are the dw that much better in the summer?
RedShft
Charlotte, NC
Nice build! Is your car a Perf. Pack car or no? I've been very impressed with the factory PP brakes so far, but have read a few people mention how they love the brake upgrades.
peppy2
east coast
Hilarious. :(
Jk. Very nice ride.
The camber kit allowed me to run a wider tire. The black rims were for summer and I was going to use the stocks for winter. I came across this set and decided to just use them instead. I would say that the summer tires are more tacky when warmed up over the all seasons. The trade off is tread wear.
