nkresho
suck, squish, bang, blow
- Pittsburgh
- Car(s)
- 2022 Q3
Hello fellow forum goers!
I've been let down by the huge lack of water/meth injection (WMI) threads around here. Coming from a mk5, I ran a dual nozzle setup with great success. I was able to run an APR 100 octane k04 tune, daily, while spraying.
So, I am starting my own thread. This will contain lots of pics, some butt dynos, and some logs.
I hope to show the benefit of spraying meth on our platform. Specifically, the GTI, running IS20 (for now). Hoping to move to IS38 down the road.
So, here's the hardware i'm starting out with:
Car:
2016 GTI S 4 door with DSG
Tune:
Eurodyne stage 2 high torque file and stage 1 DSG flash
Supporting mods:
CTS catted downpipe
CTS turbo inlet pipe
Stock Intake with AFE 5r air filter with "snow guard" removed
Stock Intercooler
Meth Components:
Devil's Own DVC 30 kit:
progressive controller
DDP5800 pump (300 PSI max)
Snow performance solenoid
Devil's Own 1 way valves (if I end up needing them)
Zoro supply (ebay) Nylon 0.25" OD / 0.180" ID tubing (400 PSI burst @ 68f)
Devils Own Nozzles
Devil's Own sandwich nozzle holder
I will be installing a single nozzle, post intercooler and pre throttle pipe. Putting it in the rubber intercooler hose, in a sandwich fitting. Pump is going in the trunk and the controller is going in the cubby under the steering wheel.
Logs:
Planning on running IAT and timing pull logs, with and without meth. I hope to see a significant reduction in IAT (at or below ambient).
As of today 5/24/16, i'm waiting on a few tanks from usplastics and the sandwich nozzle holder. I got the tubing and some of my wiring run today.
Here are a few pics to get started:
Hardware:
Controller:
Trunk (MDF plate cut to fit snug in spare tire):
Started Running the tubing:
Some of the wiring started (yellow for tank level, blue to pump, red to battery):
My favorite cutters for nylon tubing:
Lines neat and trimmed:
Pump Placement:
Through the firewall grommet:
Next to the battery:
Under the rad support:
tucked under the mount for now (till the rest of my hardware comes in):
