pulled a dsg code....
worldacgti
very weird as I scanned but the car is not behaving funny in any way. I pulled these codes....apparently stuck in every gear....news to me
System description: DQ250-6F MQB
Software number: 0D9300040S
Software version: 4310
Hardware number: 02E927770AQ
Hardware version: H52
Serial number: TFK01403250027
ODX name: EV_TCMDQ250021
Long coding: 0014
Trouble codes:
P072C00 - Stuck in Gear 1
Intermittent
P072D00 - Stuck in Gear 2
Intermittent
P072E00 - Stuck in Gear 3
Intermittent
P072F00 - Stuck in Gear 4
Intermittent
P073A00 - Stuck in Gear 5
Intermittent
P073B00 - Stuck in Gear 6
Intermittent
P072B00 - Stuck in Reverse
Intermittent
P174A00 - Partial transm. 1 valve 3 Electrical error
Intermittent
P174E00 - Partial transm. 2 valve 3 Electrical error
Intermittent
P072600 - Engine Speed Inp.Circ. Range/Performance
Intermittent
P179D00 - Cooling oil valve Electrical error
Intermittent
P079700 - Pressure Contr.Solenoid C Stuck On
Intermittent
Intermittent
P173400 - Starter release from the selector lever sensor system
Intermittent
carbongmk7
at work
well thats interesting driving around yet stuck in gear a sensor must be going haywire i wonder what the dealer will say
takemorepills
USA
I wonder if you have a marginal battery? Many times with these complicated cars a marginal battery that has more than usual voltage drop during cranking can cause the TCU/ECU to "see" all kinds of errors, or glitches, induced by a temporary lower than usual voltage drop.
gn4rwhals
Detroit, MI
Do you have a DSG tune by chance?
How does it drive, if at all?
worldacgti
Anyone have any ideas...im racking my brain here and im almost tempted to say eff it and just enjoy it.....no issues at all with driveability and no engine lights...i dont really want to take to the dealer as its a paint to have to remove everything...
Sent from my LG-H812 using Tapatalk
AxMan
CT
Audi S5
Is the car off? It may be normal codes of the car is off.
worldacgti
Honestly scared its a bad mechatronic unit...but wouldnt there be symptoms?
PRND[S]
The Lame & The Ludicrous
Southern California
'15 LSG Golf R
I would save the codes on your computer, clear them, and see if anything comes back. Unless you continue to get faults from the transmission, forget it and move on.
worldacgti
I continue getting faults....thats the most concerning thing. I have cleared them multiple times
worldacgti
Update....at the advice of my service advisor, he said unplug battery for 15 mins and drive and try again....low and behold, codes all gone.....thanks guys...
antep
Slovenia
I have got exactly the same problem now, same codes. Never had a problem with dsg before. This is very worrying..
Are you still having issues or was it solved?
