cuper steve
- SF South Bay Area
Hi Folks,
Sorry for the late/short post (way too much work). I wanted to let everyone know that this is possible.
My Reasons and Requirements:
- Running meth is awesome … its like race gas, an intercooler and an air chiller all in one
- I didn’t want meth fumes in the cabin (OK for me, but not for my kids).
- I did not want to lose the functionality of lifting the hatch floor cover - got keep secrets down there
- I didn’t want to lose any trunk space
- I wanted the convenience of doing any maintenance or tuning without having to go under the car (tweak a knob on the pump or solenoid, change/check meth filter or inspect the lines)
- The JB1 integrates amazing well with it!
Based on the requirements above, I was set on installing everything in the engine bay.
Limitations:
- I didn’t want meth near any extra hot spots (near the turbo or downpipe)
- I didn’t want liquids to be near the electronics (driver side fuse box, battery and JB1)
Tank Location:
- There was no place for the 1 gallon cube tank that met all those requirements. It may have been possible to swap out the battery for a lightweight braille battery, but it would be too close to the electronics. We pulled off all the tire liners and under trays ... no open space.
- I ended up using the windshield wiper reservior as the meth tank. The rubber grommet that one of the pumps connects to is a perfect fit for the 1/4 meth line. No need to tap the bottle or make any adjustments since its the draw side (sucking in to the pump), it should never come out.
- I also used split loom coil to cover the meth lines so they are more “stealth”
Pump Location:
- It needed to be in a convenient location, in case you wanted to test it, adjust the flow rate or replace it. I ended up getting a VWR600 intake and guess what … that thing is so huge, it sits nicely in there and I don’t believe it affects air flow that much.
- I also installed the meth filter in the intake, so when I remove the cover I can check/service it. When its covered, its a very clean engine bay look.
- Ideally you would have the pump lower than then tank, but if there isn't much difference in elevation, you'll be fine.
Tucked Under the Filter
Filter pushed aside
Solenoid Location:
- I was going to put the solenoid in the airbox as well (and may move it later), but I wanted the ability to see the methflow and test it if needed, so it was supported outside the airbox.
Wiring:
- I used the key-on power from the fuse box … there is plenty of room to stick the FSB … like its almost designed for it.
- The wires to come out and it was wrapped before, but I accidentally pulled a wire too hard and needed to debug and make sure it was still connected. So it could be a bit cleaner than it is today.
- I did dremel part of the fuse box to have allow the wires to come out and for the fuse box to close properly.
FSB Sitting On Top
FSB Sitting in the Gap
Before Using The Wiring Loom (airbox open)
The Finished Product (airbox open)
The Finished Product (airbox closed)
Street Results:
- I’m able to set my Map3 Max Boost to 6.2 PSI while running 91 octane California crap (we add a bunch of hippie garbage in our winter and summer mixes)
- Logged dozens of 2nd-mid5th gear runs with no throttle closures (ignition timing issues) - it only dropped 2 inches on the reservoir.
- Since its a progressive spray and user configurable boost settings, it doesn’t drink a lot of meth … I’ve still got 80% of a tank full since most of my driving is city driving or stuck in commuter traffic.
Drag strips are closed for the winter … May try to hit a weekend test-n-tune if I have any free time.
Other WINS:
- The built in low windshield wiper fluid dashboard alert lets you know you’re running low
- FailSafeBoard (FSB) is integrated with the JB1 will cut your Map3 boost settings to Map1 if the meth flow is ever below your threshold
- Using a Solenoid will also taper your the boost that is added based on how much meth is flowing
Other Notes:
- Running 75% meth 25% water
- Map3 with 6.2PSI boost additive
- Will do more datalogging, but it looks like it could go higher
- Here's the kit ... http://burgertuning.com/meth.html
Thanks for reading!
##### Huge Props to ncampos976! #####
He did the installation, I watch and pointed at stuff. Before this install, he’d never done one before, but he was a VW certified technician working at a dealership for 8+ years! The quality of his work and attention to detail is top notch. His movements are cautious and deliberate. I never worried about a scratch or a ding. While I was OK with rough cuts, cable ties and twisties … he insisted on soldering almost every connection and the shrink wrapping each junction. He’s able to do this install in his sleep now.
He doesn’t seem to advertise his services (so I will), I would be comfortable with him doing at least the following:
intakes
downpipes
exhaust
pulleys
springs
coilovers
big brake kit
meth injection kit
piggyback installations
and other stuff I’m sure I’ve not listed.
I drove 90 minutes to get to him based on great feedback from other local VW owners. He did the install in 1/3 the time that other “tuner shops” were quoting me. He also charges a more than fair rate for his work.
If you’re close, please consider using him, for your own benefit!
Limitations:
Tank Location:
Pump Location:
Filter pushed aside
Solenoid Location:
Wiring:
FSB Sitting On Top
Street Results:
Other WINS:
Other Notes:
Thanks for reading!
intakes
downpipes
exhaust
pulleys
springs
coilovers
big brake kit
meth injection kit
