FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Technical Topics > Golf Engine / Drivetrain / Exhaust / Tunes
Reply
Thread Tools Display Modes
Old 01-12-2018, 10:12 AM   #1
Pacman91
Junior Member
Drives: 2016 1.8tsi
EPC LIGHT keeps coming on randomly
So I've noticed since I bought my golf that after about 10,000km it would have an occasional maybe once a month (if that)problem with hesitation. Couldn't figure out what was going on but everytime it happened I was starting to turn a corner from a standstill and not even giving it hard throttle. EPC light would turn on and Flash until I took my foot off the gas and stay on until I turn off the car even though the car would balance itself out and drive normal. Looking into some other threads I found guys mention it to be an issue with the shape of our fuel tank and running low on fuel which yes a couple of those times I was running around a 1/4 tank. Most recent time was last month when I was going in a straight line from an intersection with 1/2 a tank of gas and it hesitates and misfired hard as it would when the EPC light flashed the other times, so I let my foot off the gas for a second and put it back on and the car drove fine. I thought about taking it into the dealership but they want to charge me to do a full inspection on the car which I wasn't sure if that is normal when the car is still under warranty. Is it normal for them to charge $180 cad for an inspection before knowing whether or not its warranty related?
Any other ideas on what it could be?
This what obd11 pulled up when I scanned it each of the times it threw the epc light.
OBDeleven data log
Date: 2017-12-22 12:46
VIN: 3VW217AU6GM066170
Car: Volkswagen Golf
Year: 2016
Body type: 5-dr hatchback
Engine: CXBB 125 kW (170 HP) 1.8 l
Mileage: 45801 KM
01 Engine
System description: 1.8l R4 TFSI
Software number: 8V0906264F
Software version: 0004
Hardware number: 06K907425B
Hardware version: H13
ODX name: EV_ECM18TFS0208V0906264F
ODX version: 001004
Long coding: 091A00122424002F1000
Trouble codes:
P130A00 - Hide cylinder
Intermittent
P013E00 - O2 Sensor Bank 1 Sensor 2 Delayed Response - Rich to Lean
static
Date: 2017-12-22 12:39:12
Mileage: 45800 km
Priority: 2
Malfunction frequency counter: 1
Unlearning counter: 255
Engine speed: 1653.75 1/min
Normed load value: 38.0 %
Vehicle speed: 89 km/h
Coolant temperature: 96 C
Intake air temperature: 3 C
Ambient air pressure: 940 mbar
Voltage terminal 30: 14.472 V
Dynamic environmental data: 20962810C00468141CF59A144800381424FFFE10BE014D10A4 9410BC33BF
P03AF00 - Cylinder 3 Pressure Too High
Intermittent
P03A500 - Cylinder 2 Pressure Too High
Intermittent
__________________
1.8 auto/CAI/DP/Muffler delete/OBD11 tweaks
Pacman91 is offline   Reply With Quote
Old 01-12-2018, 10:24 AM   #2
Pacman91
Junior Member
Drives: 2016 1.8tsi
It does this whether I run premium or regular gas and regardless of what gas station it comes from.
__________________
Old 01-12-2018, 06:49 PM   #3
Sandberg84
Junior Member
Drives: Golf Alltrack
I would not think they should charge you if it is the regular new car warranty everything should be covered.
They charged us (then refunded) for an inspection on an 07 GTI High Pressure fuel pump because that was an extended warranty and if it was not the HPFP there was no warranty.
Sandberg84 is offline   Reply With Quote
Old 01-13-2018, 04:35 PM   #4
TwinDad
Senior Member
Drives: 2016 sportwagen
It's overboost. You are running a downpipe with no tune. Stock ecu parameters are not adjusted for it. Does it happen at the point of shifting?
__________________
2016 GSW- JB4-IS20-e30-RS7 plugs-Piggie pipe-K&N drop in
TwinDad is offline   Reply With Quote
Old 01-14-2018, 07:17 PM   #5
Pacman91
Junior Member
Drives: 2016 1.8tsi
Quote:
No it's not at shifts points it's almost right after I press the accelerator the engine does it around 1500-2300ish rpm still in first gear and it's when I'm only applying 30%-60% throttle. It just feels like it hit a rev limiter until I release the throttle and try again.
__________________
Old 01-15-2018, 01:57 AM   #6
The Fed
Senior Member
The Fed's Avatar
Drives: 2016 Golf R
Do you have an O2 spacer on your DP?
__________________
(Mostly) Posted by Josh/AWE. Flapper valves are open at idle, close after 1100 RPM during part throttle. Full throttle 1st-4th gear the valves open until throttle let off. 4th gear, 1500 RPM to full throttle closed, closed until 3500 RPM, then open until lift off throttle.
The Fed is offline   Reply With Quote
Old 01-15-2018, 02:14 AM   #7
Pacman91
Junior Member
Drives: 2016 1.8tsi
Quote:
Yes I have the cts dp and installed the cts 90 spacer same time as dp but about once a month I clear the check engine light when it throws the o2 sensor code. I installed the dp when the car had about 500 km on it.
__________________
Old 01-15-2018, 02:18 AM   #8
The Fed
Senior Member
The Fed's Avatar
Drives: 2016 Golf R
I can't remember the make, but a certain one usually doesn't throw a light. And did you check for leaks at the ends of the DP?
__________________
Old 01-15-2018, 02:29 AM   #9
Pacman91
Junior Member
Drives: 2016 1.8tsi
Ya i know i have a small leak right in front of the resonator, clamp is just a bit loose. But I didn't think that leak there would cause any issues with upstream sensors.
__________________
Old 01-15-2018, 02:02 PM   #10
stuntnuts
Senior Member
Drives: 2016 GSW
Mine has done the exact same thing a few times since I've owned it. Same codes as you reported. Stock 1.8 engine, MY 2016. It isn't super common, but has been reported a few times on various forums.
I haven't bothered taking it to the dealership because all I'm going to get out of them is "we've never seen this before" "we don't know how to fix it" "let us sand your paint down with our complimentary car wash service". I'll just live with it.
stuntnuts is offline   Reply With Quote
Old 01-15-2018, 04:40 PM   #11
Pacman91
Junior Member
Drives: 2016 1.8tsi
Ya that's why I haven't bothered taking it in yet. I'm wondering if when I tune it in the future if this hiccup will disappear.
__________________
Old 01-15-2018, 05:01 PM   #12
stuntnuts
Senior Member
Drives: 2016 GSW
Quote:
I'm 99% sure it's a software issue, so yeah, I bet it would.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
