FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Technical Topics > Tracking / Autocrossing / Driving Techniques
Reply
Thread Tools Display Modes
Old 12-18-2017, 03:38 PM   #1
jmason
Senior Member
Drives: 2015 GTI S 4 Door 6MT Night Blue Metallic with LP
Looking for Track Day A/V Recommendations
I would like to use one camcorder center-mounted in the car (an over the shoulder viewpoint), one mic to pick up engine sound (next to exhaust pipe?), and use the audio from in-car driver/passenger intercom (Chatterbox Tandem Pro 2). I guess I would need a mixer to combine audio for input to camcorder. I would appreciate any recommendations on equipment for this setup.
Thanks.
__________________
3M Crystalline 50% tint | P3 Cars VIDI Display | Bilstein PSS10 | Michelin PSS 235/40 | Cross-Drilled and Slotted rear Rotors | Short Shift Kit | Tyrolsport Deadset | BFI Catch Can | Neuspeed REs12 18 x 8 Bronze | Eurocode Adj F & R SBs | SuperPro End Links | BFI Weighted Shift Knob | Brembo 330mm BBK | Solid Shifter Bushings | SuperPro Alloy 0006K LCA | CSS Swivels | TT Front Bearings | Wavetrac LSD | RSR Clutch Kit
jmason is offline   Reply With Quote
Old 12-20-2017, 08:23 AM   #2
MeltedSolid
Senior Member
MeltedSolid's Avatar
Drives: Mk7 Golf TSI Launch Edition
I like a helmet cam because it lets the viewer know what's going through the driver's head at any given time. Also, if at the end you just have a bunch of separate audio files you can just combine them in a video editor.
__________________
2015 TSI Launch Edition | Deep Black | 5-spd manual | APR Stage 1 + JB4 + IS20 swap | DIY Turbo Muffler Delete | 17" Enkei RPF1's | 034 dogbone insert V1 | BC Racing BR series Coilovers | ST 25mm rear sway bar | DIY HD Clutch Stop | NGK RS7 Spark Plugs | VWR Catted Downpipe
MeltedSolid is offline   Reply With Quote
Old 12-21-2017, 10:30 PM   #3
CosmosMpower
Member
Drives: BMW M2, BMW M3, 997 GT3
Aim smarty cam and solo DL it can record video, car and the GPS unit outputs and sound from an external source and combine everything as it records.
CosmosMpower is offline   Reply With Quote
Old 01-03-2018, 09:36 PM   #4
Zacr81
Senior Member
Zacr81's Avatar
Drives: 2015 GTI
Easy.
Two go pros or cameras of your choice. one inside for video and the other for audio. When you edit the video you can take the audio from one and layer it. Very easy to do and probably the easiest option.
I stick my camera upside down on the sunroof and it gets a good angle.
https://www.youtube.com/watch?v=xg9O42ahAhY&t=191s
__________________
WWW.YOUTUBE.COM/THEDAILYBOOST | INSTAGRAM @THE.DAILY.BOOST
Zacr81 is offline   Reply With Quote
Old 01-03-2018, 10:21 PM   #5
sidepocket
Member
sidepocket's Avatar
Drives: 2015 GTI MK7 DSG Autobahn Stage 1 APR
https://www.youtube.com/watch?v=I_D6mI5O4sw
Here's my latest monstrosity. Two GoPros, external sound (Zoom H1 in the car, microphone in the engine bay), data recorded on my phone (TrackAddict app), then put it all together on the computer (RaceRender).
It takes a while to sync all four sources accurately, but I like the results.
__________________
'15 GTI 4dr DSG AutoBahn
APR Stage 1, Neuspeed RSB, Neuspeed SS brake lines, EBC Yellow pads, Michelin PSS
sidepocket is offline   Reply With Quote
Old 01-04-2018, 02:17 AM   #6
jmason
Senior Member
Where did you put the mike in the engine bay? How did you route the cable?
__________________
Old 01-04-2018, 07:33 AM   #7
big residual
Junior Member
Drives: Golf R
Ymmv, but my Garmin Virb Ultra 30 has produced much better results than my GoPro Hero5 Black. Much better image stabilization and auto-exposure adjustment. Not sure if the GoPro 6 caught up, but the Virb also records basic gps data for speed, time and track. Creating a light version of the full Harryís or RaceRender instrumented video is super easy. Not as much data but zero effort.
big residual is offline   Reply With Quote
Old 01-04-2018, 03:36 PM   #8
ADVNTURR
Member
Drives: 16 Golf R, 05 350Z TT, 86 F250, 91 XJ
This is going to be a long post, so fair warningÖ
To answer your question I think you first need to ask yourself a few questions:
1) Do you have anything else in your life that you want to take rugged video of?
2) How much information do you want to have in your track videos
3) How much editing are you willing to do to make the videos come out the way you want?
If all you ever expect yourself to want to do is track videos, then some of the dedicated track recording systems mentioned by others above are probably the way to go. If you are like me, and probably a lot of other people who arenít racing competitively and are just out for a good time, then your better bet is probably something more along the lines of a GoPro/Garmin rig.
I personally run the following equipment:
-- Garmin Virb Ultra 30 w/ Bluetooth OBDII dongle Ė mounted on the hood with a GoPro suction mount
-- GoPro Hero4 Silver Ė mounted on the rear with a GoPro suction mount
-- GoPro Hero4 Black (loaner from a friend) w/ external mic adaptor and Olympus Stereo Mic Ė mounted either to a stick-on mount on the center console or with a GoPro suction mount on the inside of the windshield
For video editing I use the following:
-- Garmin Virb Edit software to pre-render the front Garmin camera and add all of my gauge and GPS data
-- Cyberlink PowerDirector editing software to piece together the 3 cameras, create the picture-in-picture layout, and mute the 2 external cameras
A couple example videos from my setup (from my Z, not my R):
Autocross: https://youtu.be/qpJnUVl6kec
HPDE: https://youtu.be/TtLXnuTSXmA
Equipment reviews:
-- As far as my equipment goes, I canít speak highly enough of the GoPro suction mounts. Iíve been north of 130mph and they have been rock solid (but I do use some 3mm high-tensile cord from a climbing shop to make tethers just in case). GoProís mounts in general are very good including the rollbar, the handlebar (which works on head rest posts), and the stick-ons. One thing I highly recommend is getting one of the thumbscrew wrenches to make sure things donít move/vibrate at speed
-- GoPro Ė My experience has been nothing but positive with GoPro. Their remote is awesome and can power multiple cameras on/off and gives you a visual indication of how many cameras are connected and what the cameras are doing. I think the picture quality, on the Hero4 at least, is better than my Garmin Ultra 30, especially in lower light. The touch screen on my 4 Silver has always worked well and I do get good battery life out of the camera. My Hero4 case system has been more robust and easier to deal with than the Garminís and I donít have the issues with lens fogging that I do with my Garmin.
-- Garmin Ė The feature set on the Garmin Virb Ultra 30 with the built-in GPS, ability to tie into a Bluetooth OBDII dongle, ability to add in a heart rate monitor if you have the right type, the image stabilization, and the ability to use all of GoProís mounts made it too tempting to pass up. I think GoProís newest cameras have some of those features now but I havenít gotten to test them. Garminís remote is absolute garbage compared to the GoPro one and I have had many instances of lost video because the remote un-paired itself. Garminís editing software is also better than GoProís and the process of adding gages is very easy. One thing that Garmin claims but I havenít been able to verify, is that if you use multiple Ultra 30s, you can sync them using the GPS timestamp which would be very handy.
Iíll cut myself off here and if you or anyone else has any questions or wants any information/opinions Iíll be glad to give them.
ADVNTURR is offline   Reply With Quote
Old 01-04-2018, 05:00 PM   #9
Lord_Flexington
Senior Member
Lord_Flexington's Avatar
Drives: '15 GTI LP PP|'01 CBR 929
+1 for trackattack app!
__________________
2015 GTI S PP//JB1//DP//INJEN CAI//GFB DV+//VMRV705//VWR SPRINGS//PZERO ROSSO//SPULEN SS//RACESENG//OBD11//Deep Pearl Gang//BIG WANG GANG
P1 GTI TCR-->http://www.golfmk7.com/forums/showthread.php?t=25994
Lord_Flexington is online now   Reply With Quote
Old 01-04-2018, 05:14 PM   #10
jmason
Senior Member
ADVNTURR,
Thanks for your informative post.
What I want from an in-car system is to record video and data so that I can to create a product that I can use for self coaching.
My track days are a hobby, so I can't justify nor do I need a dedicated data acquisition system. I have considered GoPro and similar, but I don't have a use for this type of camera beyond track days, so it seems a little extravagant to go that route.
I have used a micro 4/3 camera for video, Wifi dongle for OBD data acquisition, and my cell phone running TrackAddict for data, GPS, and dynamics recording. I use Race Renderer to put it all together. It has worked pretty well, but the camera has some drawbacks that I need to address (recording time, ease of start/stop recording).
To mount the camera and phone, I have a bracket that attaches to the headrest posts. The organization that I typically participate with does not allow suction mounts. I don't have a roll bar.
I have recently purchased a consumer-level palm camcorder to replace the micro 4/3 camera. My initial experience hasn't been all that I had hoped. There is a lot of vibration in the video (at least when driving on city streets) that needs to be addressed. Also, the focal length is a bit too long.
So now I am trying to address the vibration of the camera. I'm thinking that butting it up against the headrest may dampen vibration. Also, if I mount the bracket to the driver side seat, my body may help reduce seat vibrations. If the outside temps ever get above 20, I'll run some experiments!
__________________
Old 01-04-2018, 07:06 PM   #11
sidepocket
Member
sidepocket's Avatar
Quote:
Most lavalier microphones come with a little alligator clip. I just clipped it to the cloth battery cover in the engine bay. I have a nice puffy deadcat cover on it to cut the wind noise down even more.
__________________
Old 01-04-2018, 07:17 PM   #12
jmason
Senior Member
Thanks. I was thinking about the same general area. That location might also be somewhat sheltered from engine heat.
__________________
Old 01-04-2018, 08:44 PM   #13
sidepocket
Member
sidepocket's Avatar
https://www.youtube.com/watch?v=cAImkVn893s
Here is one I did with a headrest GoPro mount, before I sorted out my audio. Having it attached to the driver's side headrest definitely helps with vibrations.
__________________
Old 01-04-2018, 09:19 PM   #14
jmason
Senior Member
Thanks sidepocket!
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
