FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Regional Forums > AUSTRALIA
Reply
Thread Tools Display Modes
Old 08-13-2017, 05:04 AM   #1
GTI40
Junior Member
Steering wheel off to left! Help!
Hey guys - my 40th anniversary GTI has developed an annoying issue - steering off to the left - my local VW dealership claims this is normal. This all came about after the car went in to have the turbo charger replaced - prior to this the steering was perfect.
The wheels have been alligned 3 times with no success - it is consistently off 5 to 8 degress off to the left with no crown on road (flat road). The car however still tracks dead straight with the wheel off to the left.
It may not seem like much but with such sensitive steering it becomes extremely annoying and seems to wreck the driving experience.
Please see the picture - how can I get this fixed?! Thanks in advance.
Sent from my SM-G935F using Tapatalk
GTI40 is offline   Reply With Quote
Old 08-13-2017, 04:33 PM   #2
Senior Member
Sandman GTI's Avatar
Drives: GTI MK7 Autobahn, PP, DCC+LP, 97 F-150 4.6L V8
This can be adjusted by a shop who knows how to work on cars.
It is part of an alignment check. They adjust them at the factory so they can adjust them at a dealer.
You either need to meet with the Service Manager and based on his response decide what is next. Or, find a better dealer service dept.
It can be easily fixed for a shop.
My wife's Tucson had to be adjusted.
I have had my Truck adjusted after an alignment.
__________________
Sandman
My Build Thread: http://www.golfmk7.com/forums/showthread.php?t=6100
Sandman GTI is offline   Reply With Quote
Old 08-13-2017, 04:42 PM   #3
breaking badly
Banned
Drives: Winnie Twister
Quote:
Not normal, and they definitely did not perform a proper alignment.
It's quite a simple job (by adjusting front and/or rear toe) getting
the steering wheel straight. Guess they need to do it again.
On a side note, I wonder if they thought they needed to remove or
shift the subframe to swap the turbo. Actually that isn't necessary.
breaking badly is offline   Reply With Quote
Old 08-13-2017, 05:40 PM   #4
Gti jake
Senior Member
Drives: GTI 6MT
I'd never go back to that dealer, even Firestone was able to get my alignment right on the first try.
__________________
'16 GTI 6MT PM for NC/SC help with Installs & Fabrication
Gti jake is offline   Reply With Quote
Old 08-13-2017, 06:55 PM   #5
MonkeyMD
Senior Member
MonkeyMD's Avatar
Drives: 2016 VW Golf Tsi S Manual
+1 for Firestone. And you can get lifetime alignments
MonkeyMD is offline   Reply With Quote
Old 08-13-2017, 08:00 PM   #6
Gawernator
Senior Member
Gawernator's Avatar
Drives: '17 Wolfsburg 1.8T; '15 ZX6R Racebike (x2)
Quote:
Lol. That is pretty sad for the dealer in question
__________________
Watchdog Armory Racing AFM #725 Thanks to my 2018 Sponsors:
JPH Suspension | AXO Racing | Armour Bodies | BELL Helmets | EVLUTION Nutrition | Forcefield Armor | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Gawernator is offline   Reply With Quote
Old 09-13-2017, 09:34 PM   #7
wild pete
Member
wild pete's Avatar
Drives: 2014 MK7 2.0 GTTDI 3 dr Tornado red
easy diy fix you need to screw the drivers side track rod out a bit and the other side track rod in a bit the same amount so it does not upset the wheel alignment until the wheel is straight
wild pete is offline   Reply With Quote
Old 10-16-2017, 07:03 PM   #8
Sean Cymru
Member
Drives: 2016 GTI DSG PP
I had wheel alignment issues too on my MK7 GTI PP. I had a 4 wheel lazer alignment (hunter) done, but steering wheel was still off centre. Took it back and it was still off centre. Then I took it to a different alignment garage where they only aligned the two front with old fashion techniques (weights or some sort, no lazer) and then my steering wheel was bang on centre. It was so much cheaper too.
Sean Cymru is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
