FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Volkswagen GTI / Golf MK7 General Topics > Golf R Discussions
Reply
Thread Tools Display Modes
Old 04-20-2017, 07:44 PM   #18
Senior Member
Sandman GTI's Avatar
Drives: GTI MK7 Autobahn, PP, DCC+LP, 97 F-150 4.6L V8
Quote:
Originally Posted by ImolaR View Post
Sounds like the Iron-X would be great to use on the wheels..I never heard of the stuff before now.
Yes on wheels.
Just never let it dry.
I was car first.
Then Iron-X a panel at a time. Let sit 5 min. Wipe down with MF to make sure it gets everywhere. Hose off. Wash car again quickly. Clay and wax as you like.
Every 6 months is good unless you want more.
__________________
Sandman
My Build Thread: http://www.golfmk7.com/forums/showthread.php?t=6100
Sandman GTI is offline   Reply With Quote
Old 04-21-2017, 12:41 AM   #19
EmptyHeaded
Junior Member
Drives: 2003 EJ205 Wagon
Quote:
Originally Posted by alexspeed3 View Post
Learning a lot from this discussion. Is what you refer as sealant same as wax?
Think of sealants as modern day waxes. They're made up of polymers that are designed to bond to the surface of your paint to provide a durable protection against the elements. While they don't provide the same depth and gloss as your traditional carnuba waxes, they definitely provide additional protection and durability between treatments, meaning you don't have to re-apply as frequently. To take it a step further, many people like to use a sealant after they wash and then top the sealant with a wax, just to help bring out that additional depth and gloss that they might not get with a sealant alone.
To properly do a detail I am understanding the following:
Rinse
Ironx
Rinse
Clay
Sealant then wax?
These are good steps for a full detail, however once you've established a solid foundation for protection, you can simply wash and dry your car as you would normally to keep it looking nice and clean. Generally I'll detail my car 2x a year, but only Iron X/clay it 1x. Washes usually consist of me washing with 2 bucket method, with the rinse bucket being a mix of clean water and Optimum No Rinse mixed in, and then towel dry with a hydrophobic quick detailer spray/sealant (I like Chemical Guys V07), and be done with it. With a bit of work on the front end, it really makes it easy to maintain and keep looking great with minimal effort over time!
EmptyHeaded is offline   Reply With Quote
Old 04-21-2017, 01:17 AM   #20
Gogo GTI
Senior Member
Gogo GTI's Avatar
Drives: 2017 GTI Sport DSG
Any opinions about nanoskin? I've read enough to convince me to buy it but haven't had the chance to use it yet. Just thought I'd get additional opinions if I could before giving it a try.
Gogo GTI is online now   Reply With Quote
Old 04-21-2017, 11:43 AM   #21
AdrenalineChick
Senior Member
AdrenalineChick's Avatar
Drives: 2016 Golf R
This is a life changer:
https://www.amazon.com/Speedy-Surfac...rds=clay+towel
It's a clay bar in towel form. Cuts claying time in half or more. If you drop it, just rinse it off.
Not sure what you guys are using for clay, but for anyone that doesn't know about this, get one! I used it on my white MK6 GTI and it got brake dust off the paint with almost no effort. Just make sure you use a sealant after (I use Sonax Polymer Net Shield, which also changed my life).
__________________
~Kimberly~
2016 Golf R | Lapiz Blue | DCC/Nav/DAP | 4 door | 6MT
AdrenalineChick is offline   Reply With Quote
Old 04-21-2017, 12:41 PM   #22
17lc9x
Junior Member
Modern vehicles are all basecoat clear coat. Usually a waterborne basecoat with a solvent borne clear coat. Only one manufacturer makes a water borne clear coat but it hasn't caught on (slow dry times). Older cars and large vehicles (think buses and trucks) used or still use single stage acrylic enamels or acrylic urethanes. Base/clear is much more durable and you won't see paint transferring to your clay bar or compound pad.
17lc9x is offline   Reply With Quote
Old 04-21-2017, 12:41 PM   #23
Porknozzle
Junior Member
Porknozzle's Avatar
Drives: 2017 R
Quote:
A word of caution here. Contaminants removed using a traditional clay bar are embedded into the clay away from the surface. Non-clay-bar substitutes do not and you can do more harm than good because the contaminants are trapped between the paint and whatever else you're using.
I know Nanoskin is popular and one of the first products of its kind but now everyone is jumping on this bandwagon and some are so bad you'll end up with this mess like I got on my Challenger with Clayzilla from Surf City Garage. And yes, I used it according to instructions, wrote the manufacturer, got a refund after two replacements failed.
What you see here isn't the results of trapped contaminants, the Clayzilla pad is actually abrasive, another surprise awaiting those looking for a better mousetrap.
Porknozzle is offline   Reply With Quote
Old 04-21-2017, 04:57 PM   #24
sixspeedz
Member
sixspeedz's Avatar
Drives: 2016 Golf R
Nice job OP... I bought the same kit last weekend and plan on hitting the car next week followed by an application of Hydro2... Just waiting on my new pressure washer to come in
Nice to see it came out so clean with no polishing needed!
__________________
2016 LSG Golf R - Stage 1 (V2.3 93 Octane HIGH TQ) | APR short shift kit | SB Stage 2 Daily clutch | K&N filter
sixspeedz is offline   Reply With Quote
Old 04-21-2017, 05:03 PM   #25
ImolaR
Senior Member
ImolaR's Avatar
Drives: '16 Golf R (6MT) & BMW R nineT (motorcycle)
Thanks. What washer did you pick up? I use a small Karcher thats made for cars.
__________________
Follow me on Instagram @GTEurope !
ImolaR is offline   Reply With Quote
Old 04-21-2017, 06:21 PM   #26
sixspeedz
Member
sixspeedz's Avatar
Drives: 2016 Golf R
I have a SunJoe SPX3000 on it's way and some Chemical Guys honeydew snow foam. I think I'll get some Iron-x before I do the work though.
We have 3 cars to maintain, so all this stuff pays for itself after only one summer of avoiding the commercial car washes.
__________________
Old 04-21-2017, 06:40 PM   #27
Diggs24
Senior Member
Diggs24's Avatar
Drives: 2015 GTI; 2003 Saab 9-3 SS
I use it and it's great. Just don't push really hard with it or the "clay" will come off the pad. Use plenty of lube. I use a diluted batch of Optimum No Rinse.
Be sure to break it in on a glass window first per the directions.
Diggs24 is online now   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
