FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Technical Topics > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Reply
Thread Tools Display Modes
Old 12-17-2016, 06:22 AM   #1
rex n effect
Junior Member
Drives: '15 Golf R, Hyundai misfire'r'us santa fe
What does maintenance manual say about front camber?
If it's out of spec - does the VW maintenance manual allow for any adjustments of front camber by other means, as it seems not adjustable from factory.
Thanks!
Sent from my SM-G900V using Tapatalk
rex n effect is offline   Reply With Quote
Old 12-17-2016, 11:49 AM   #2
Gti jake
Senior Member
Drives: GTI
There's no factory front camber adjustment, you'd need camber plates. Or, just buy coilovers or air ride that includes them and kill two birds with one stone
__________________
'16 GTI
Gti jake is offline   Reply With Quote
Old 04-21-2017, 12:43 PM   #3
odessa.filez
Senior Member
odessa.filez's Avatar
Drives: 2016 GSW 1.8T S
or find the damaged suspension part causing camber to be out of spec and replace it.
camber plates are no walk in the park labor wise, tend to require periodic maintenance, and can introduce lots of NVH. Most on the market are purposed to introduce excess negative camber for spirited/competition driving with limited concern for ride quality or nvh.
Sent from my Nexus 6 using Tapatalk
__________________
..it could be made into a monster if we all pull together as a team.
odessa.filez is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
