FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Off-Topic Discussions > General Car News and Discussions
Reply
Thread Tools Display Modes
Old 12-07-2017, 05:59 AM   #1
MonkeyMD
Senior Member
MonkeyMD's Avatar
Drives: 2016 VW Golf Tsi S Manual
It's not turbo lag
So all this time I've been using the term turbo lag to refer to boost threshold. Hmmm. Learn something new everyday.
https://jalopnik.com/boost-threshold...ing-1821055465
MonkeyMD is offline   Reply With Quote
Old 12-07-2017, 06:20 AM   #2
MeltedSolid
Senior Member
MeltedSolid's Avatar
Drives: Mk7 Golf TSI Launch Edition
I always new they were different, but I never had a name for boost threshold so I ended up just referring to it as turbo lag as well. I always thought the term lag didn't really define how the engine isn't capable of spinning up the turbo at low rpm very well.
__________________
2015 TSI Launch Edition | Deep Black | 5-spd manual | APR Stage 1 + JB4 + IS20 swap | DIY Turbo Muffler Delete | 17" Enkei RPF1's | 034 dogbone insert V1 | BC Racing BR series Coilovers | ST 25mm rear sway bar | DIY HD Clutch Stop | NGK RS7 Spark Plugs | VWR Catted Downpipe
MeltedSolid is offline   Reply With Quote
Old 12-07-2017, 07:03 AM   #3
Gti jake
Senior Member
Drives: GTI 6MT
Yeah that's a few minutes I'll never get back. Boost threshold isn't mistaken for turbo lag...just nobody talks about it because you'd never be WOT or expecting boost in that situation.
Yeah no, ah!t you're not gonna make boost in 6th gear at 1,100 Rpm...
__________________
'16 GTI 6MT PM for NC/SC help with Installs & Fabrication
Baun Performance https://facebook.com/Baun-Performance-406768406417784/
Gti jake is online now   Reply With Quote
Old 12-07-2017, 09:06 AM   #4
MeltedSolid
Senior Member
I think Jason has the problem that a lot of experts in their field have, where they view most things regardless of complexity as super obvious and basic, and have a hard time differentiating what the average person will find obvious or not. Half the time I watch his videos and think that everyone and their mother's pets could figure that out, but then the other half of the time I come out of it having actually learned something that could change my perspective on how a thing works.
__________________
Old 12-07-2017, 12:49 PM   #5
Hoon
Senior Member
Hoon's Avatar
Drives: '17 GTI Sport DSG
Another good topic is pressure vs flow.
Boost pressure is the most pointless and irrelevant number that people love to talk about.
Quote:
It's constantly mistaken for turbo lag.
Not everyone has a stock turbo, either. Do you hear people describe big turbo cars as laggy, or having a high boost threshold?
__________________
FBO / IS38 / Stratified
Hoon is online now   Reply With Quote
Old 12-07-2017, 11:42 PM   #6
The Fed
Senior Member
The Fed's Avatar
Drives: 2016 Golf R
He didn't address throttle angle during these events.
__________________
(Mostly) Posted by Josh/AWE. Flapper valves are open at idle, close after 1100 RPM during part throttle. Full throttle 1st-4th gear the valves open until throttle let off. 4th gear, 1500 RPM to full throttle closed, closed until 3500 RPM, then open until lift off throttle.
The Fed is online now   Reply With Quote
Old 12-08-2017, 12:15 AM   #7
MyGolfMk7
Senior Member
MyGolfMk7's Avatar
Drives: Audi B5 S4 | Mazdaspeed MX-5
This statement is believable "Boost Threshold And Turbo Lag Aren't The Same Thing"
This statement is not "Turbo lag is the additional time delay above boost threshold, when the engine’s throttle valve is open and the turbocharger needs to accelerate to deliver positive pressure to the engine."
Think about this statement "Basically, boost threshold is the engine speed at which you have enough exhaust gas flow in order to create boost."
If the engine is at the boost threshold, the point where it can create boost because there's enough exhaust gas flowing through the turbine, then there is no lag, because the turbo is already in a condition where it can produce boost.
Plus the definition of turbo lag is inadequate, it cannot be measured. It sounds like it is supposed to start at boost threshold (time delay), but when does it end?
__________________
MyGolfMK7.com
MyGolfMk7 is offline   Reply With Quote
Old 12-08-2017, 08:38 AM   #8
Gti jake
Senior Member
Drives: GTI 6MT
Nobody's ever been driving along in 6th gear with their buddies in the car and said "alright I'm gonna do a pull" and just floor it without down shifting...that's the kinda situation where someone would incorrectly say "man this turbo is laggy"
Nope...you'd down shift to second or third to bring the rpm up (now you're above boost threshold) and lay into it. If someone then said man this turbo is laggy they'd be exactly correct.
I also don't get the "not everyone has a stock turbo" comment above either. Not only would the above still apply exactly the same, it would be even less likely that you wouldn't brake boost and skip Boost Threshold and lag (for the most part) all together.
__________________
Old 12-08-2017, 09:31 AM   #9
Ismetz
Member
Drives: Mk7 gti
I do however experience some lag when I wanna do pull from 50 mph in 3 gear. My rpm are around 3700 and it takes a solid second for it to built up boost. Would brake boosting be beneficial sense the stock is20 still relativley small?
__________________
APR stage 2 93 octane tune, APR dsg tune, APR high flow down pipe, APR intercooler, APR turbo inlet, afe intake, CTS turbo 3" Cat-back exhaust , 034 Motorsport dog bone insert, Enkei Raijin 18" wheels, Michelin pilot p4s tires 245/40 18"
Ismetz is offline   Reply With Quote
Old 12-08-2017, 11:52 AM   #10
Gti jake
Senior Member
Drives: GTI 6MT
Brake boosting works really well, you can leave from 30ish mph in 2nd or 50ish in 3rd at almost full boost.
__________________
Old 12-09-2017, 05:34 PM   #11
The Fed
Senior Member
The Fed's Avatar
Drives: 2016 Golf R
Video doesn't address load either. If you go by the video alone you would think our threshold is between idle and 1800 RPM since we can make max torque at 1800 RPM, and there wouldn't be any lag.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
