FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Technical Topics > Tracking / Autocrossing / Driving Techniques
Reply
Thread Tools Display Modes
Old 02-16-2018, 05:07 PM   #1
richard_rsp
Junior Member
Drives: 2017 Golf TSI Wolfsburg
Street Touring changes for SCCA 2018 Autocross
I’m kind of surprised no one has really discussed the changes to Street Touring class for 2018!
First of all, it appears that MK7 1.8 Golfs and GTIs will be moving to a new STH class. Seems like most of the same competition, Focus/Fiesta STs, MINIs, WRXs, so that’s not a huge change from the STX category (a little more difficult for us 1.8 People though!)
But what IS a huge change is the allowance of boost modification to the ECU! The rules say that:
Quote:
“F. The engine management system parameters and operation of internal combustion engines may be modified only via the methods listed below. The Check Engine Light (CEL) or Malfunction Indicator Light (MIL) may be disabled via software. Only sensors equipped from the manufacturer may be used for engine management. Data acquisition modifications to the wiring and PCM/ECU are permitted.
1. For all model years, the following allowances apply:
a. The standard PCM/ECU may be re-programmed without restriction.
b. Fuel pressure regulator(s) may be replaced in lieu of electronic hardware or software alterations. It is not permitted to mechanically alter the fuel pressure regulation AND make other hardware or software changes to engine operation.
c. Ignition timing may be set at any point on factory-adjustable distributor ignition systems. “
This is taken from page 75 of the 2018 draft rules
While this sounds awesome for APR or Unitronic tuned owners, My question is, will this include devices like the Neuspeed PM, Dinantronics Tuner, or JB1/JB4? I’m not really sure how they work, but I don’t think they replace the fuel pressure regulator, do they? Also the statement “Only sensors equipped from the manufacturer may be used for engine management” sounds like this it might exclude that type of tuner from this class.
Hopefully someone out there is more knowledgeable...
richard_rsp is offline   Reply With Quote
Old 02-16-2018, 06:17 PM   #2
RacingManiac
Senior Member
RacingManiac's Avatar
Drives: Night Blue Metallic PP GTI 2dr 6MT
I think the line is meant for certain cars where altering programming doesn't give you the gain because it is limited by fuel pressure.
The piggy back style ECU is considered the same for all intends and purpose as a flash, to my understanding.
STH sounds interesting but I'd be more interested if I have a DSG car as the weakest link is the MT clutch for the higher boost car.
RacingManiac is offline   Reply With Quote
Old 02-16-2018, 06:42 PM   #3
richard_rsp
Junior Member
Quote:
Well, I kept reading and The only problem with that is in the next section the rules say:
Quote:
2. For 2005 and older model year vehicles:
a. A supplementary (“piggyback”) PCM/ECU is permitted. It must be plug-compatable with the standard PCM/ECU (no splices) and must connect only between the standard PCM/ECU and its wiring harness.
b. Electronic components may be installed in-line between the engine sensors and PCM/ECU. These components may alter the signal from the sensor in order to affect the PCM/ECU operation. Example: Fuel controllers that modify the signal from an airflow sensor.
To me it looks like on the MK7 (or any 2006+ car), it really only allows actual tunes, not devices like the JB4 or Dinantronics tuner. That’s a bummer, as I don’t really see much difference. I guess it DOES prevent stacking of the two tunes, though. Guess I will be looking at the APR Plus tune after all...
Yeah, same with me. I’m on a Dinantronics tuner at the moment, but a bit concerned that my clutch wouldn’t take that much abuse on a fully tuned car.
Old 02-22-2018, 01:48 PM   #4
Blade3562
Senior Member
Blade3562's Avatar
Drives: 2015 Golf LE
So this is an interesting change, but sounds like I'll be in street prepped rather than touring. No intercoolers in STH and no mechanical boost upgrades. I believe that includes the IS38 on a 1.8T lol. I guess I need to re-read the rules, last year I ran STX and was really competitive but I have a feeling that won't be the case anymore lol.
Blade3562 is offline   Reply With Quote
Old 02-22-2018, 08:16 PM   #5
richard_rsp
Junior Member
wow!... I'm afraid that the IS38 is going to bump you to Street Modified. Under the Street Prepared category (Page 90) it says:
"No hardware changes or alterations to turbocharger(s) or supercharger(s), in size or number, are permitted. Turbochargers or
superchargers may be updated/backdated only in conjunction with the accompanying complete engine unit."
Old 03-10-2018, 02:55 AM   #6
scrapin240
Senior Member
scrapin240's Avatar
Drives: '17 GTI Sport, '15 F30 335xi
what's the tire dujour these days?
scrapin240 is offline   Reply With Quote
Old 03-12-2018, 01:26 PM   #7
RacingManiac
Senior Member
Rival S 1.5 or RE71R
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
