FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Technical Topics > Wheels / Tires / Suspension / Brakes / Chassis - Sponsored by The Tire Rack
The Tire Rack
Welcome to the Wheels and Tires section of GOLFMK7. This area is proudly sponsored by The Tire Rack.
If you are making a purchase from TireRack, please help support GOLFMK7 by clicking through to them with this link or clicking on the Tire Rack banner ad. Doing so helps give back to GOLFMK7 so we can keep this place running!
Reply
Thread Tools Display Modes
Old 10-19-2017, 12:53 AM   #1
Hammersticks
Senior Member
Hammersticks's Avatar
Drives: 2016 GTI PP MT
034 Negative Camber Strut Mounts
Rumor mill alert: I had heard about the possible development on vortex and confirmed with 034 that they are currently developing fixed position negative camber strut mounts. They are currently being tested on their shop MK7, S3, and MK3 TT RS cars.
Apparently they are supposed to provide around 2 degrees of negative camber but I guess we will see what comes out of testing.
The release date is TBD. Now let's just hope they aren't $$$$.
__________________
Less is more...
Hammersticks is offline   Reply With Quote
Old 10-19-2017, 01:01 AM   #2
Joel
Senior Member
Joel's Avatar
Drives: 2017 GTI 6MT
This makes me smile.
__________________
JB4, MAP cat DP, IE IC, HPA Dogbone, 034 E/T mounts, 034 R Sway, Revo TIH, Brisk Silvers, DG Sigma 6, Raceseng. Not installed yet Sachs SRE, iAbed rear main seal.
Joel is offline   Reply With Quote
Old 10-19-2017, 01:37 AM   #3
odessa.filez
Senior Member
odessa.filez's Avatar
Drives: 2016 GSW 1.8T S
that would be good.
Dinan made this type of thing for BMWs, basically added around -0.7. It also added 1/8 to a 1/4 ride height. Their design worked with the oem mount. People claimed minimal added nvh.
Would think 034 would have to design a new mount top to bottom.
__________________
Former Big Money Wasted snob
Vorshlag camber plates - PP rear sway - Koni Yellows -
ESC OFF
odessa.filez is offline   Reply With Quote
Old 10-19-2017, 01:59 AM   #4
yirayira
Senior Member
Drives: 2015 GTI 6MT
The MQB platform needs front camber adjustment outside of moving to camber plates. I have been hoping to see SuperPro release adjustable ball joints for the MK7 like on the MK6.
Fingers crossed there is a good option coming!
yirayira is offline   Reply With Quote
Old 10-19-2017, 02:38 AM   #5
Hammersticks
Senior Member
Quote:
Originally Posted by odessa.filez View Post
that would be good.
I would welcome another 1/8 to 1/4" ride height in the front.
And yes I can't imagine it not being a complete redesign.
__________________
Less is more...
Old 10-19-2017, 03:08 AM   #6
odessa.filez
Senior Member
yeah the dome for the oem mount would be hard to carry over.
springs are also a limiting factor on how much change can be provided. For my GSW with adjustable plates, I can't quite add -1.5 on one side due to spring rub on the tower.
edit:
you can see how close it gets even with coil over springs, here:
http://www.golfmk7.com/forums/showthread.php?p=524952
I think my stock springs may have larger od.
__________________
ESC OFF
Old 10-19-2017, 03:29 AM   #7
MonkeyMD
Senior Member
MonkeyMD's Avatar
Drives: 2016 VW Golf Tsi S Manual
Subbed
MonkeyMD is offline   Reply With Quote
Old 10-19-2017, 03:16 PM   #8
SlowJim
Senior Member
SlowJim's Avatar
Drives: 16 Golf R DSG
__________________
By personally using up all of the oil remaining in the world I am simply accelerating the push towards progress in the form of alternative fuels.
SlowJim is offline   Reply With Quote
Old 10-19-2017, 03:23 PM   #9
jmason
Senior Member
Drives: 2015 GTI S 4 Door 6MT Night Blue Metallic with LP
Acccording to the following response, it's not going to happen:
"Sorry, no adjustable ball joint in the works for the MK7 any longer as the packaging limits the ability to offer adjustment and proper geometry thereafter.
Kind Regards,
Brett Hauschild
North American Sales Manager
1583 El Camino Real | Millbrae | CA | 94030
Phone: +1 650 362 8016
Mobile: +1 650 796 4677
Email: bretth@superpro.com.au
Web: www.SuperProUSA.com"
CSS swivels will provide additional (fixed) negative camber.
__________________
3M Crystalline 50% tint | P3 Cars VIDI Display | Bilstein PSS10 | Michelin PSS 235/40 | Cross-Drilled and Slotted rear Rotors | Short Shift Kit | Tyrolsport Deadset | BFI Catch Can | Neuspeed REs12 18 x 8 Bronze | Eurocode Adj F & R SBs | SuperPro End Links | BFI Weighted Shift Knob | Brembo 330mm BBK | Solid Shifter Bushings | SuperPro Alloy 0006K LCA | CSS Swivels | TT Front Bearings | Wavetrac LSD | RSR Clutch Kit
jmason is offline   Reply With Quote
Old 10-19-2017, 08:50 PM   #10
A3SBQ
Senior Member
Drives: VW Golf 7 R
Sub'd. My prayers have been heard ��
A3SBQ is offline   Reply With Quote
Old 10-20-2017, 03:31 PM   #11
odessa.filez
Senior Member
for $250 or less, they should sell well.
regarding adjustable plates, mine are quite tolerable though I'm riding on 15s and keeping the front suspension soft. The increased steering feel and response is a plus. might push others over the nvh cliff with 18s and aggressive setup elsewhere.
it will be interesting to see 034's approach especially if they're adding more than -1.0
__________________
ESC OFF
Old 11-14-2017, 07:01 PM   #12
A3SBQ
Senior Member
Drives: VW Golf 7 R
Bump for info
Old 12-19-2017, 01:51 PM   #13
034Motorsport
Senior Member
Drives: MkVII GTI, Dacia Sandero
Is it still cool to bump old threads?
We've been testing these for several months now on a multitude of in-house cars (including my GTI), and they are absolutely phenomenal! Lots more grip, very quiet, easy to install, and a robust, rebuildable design.
More info can be found here on our site!
034Motorsport Dynamic+ Camber Mounts for Mk7 Volkswagen Golf/GTI/R & 8V/8S Audi A3/S3/RS3/TT/TTS/TTRS
__________________
034Motorsport - Engineering and Manufacturing Performance Hardware & Software Upgrades for Volkswagen Enthusiasts Since 2005.
YouTube // Instagram // Facebook
034Motorsport is offline   Reply With Quote
Old 12-19-2017, 02:37 PM   #14
THEREALVRT
Senior Member
Drives: MK7 GTI
nice
THEREALVRT is offline   Reply With Quote
Old 12-19-2017, 03:32 PM   #15
Senior Member
Sandman GTI's Avatar
Drives: GTI MK7 Autobahn, PP, DCC+LP, 97 F-150 4.6L V8
Any issue with the top of new mount being metal and mounting up to a painted metal frame member? I know if installed right should not move but wondering about over time if it will develop issues.
With more camber is this more a track set up or daily driver usable?
On older tires I see inside edge wear now up front and with more camber would this increase.
Are these the units you have been developing for over a year now? I talked to 034 a good while ago and they had started to test a new mount. Any issue with noise?
This unit does not use the OE bearing? Looks like OE bearing sits in same spot between it and shock.
__________________
Sandman
My Build Thread: http://www.golfmk7.com/forums/showthread.php?t=6100
Sandman GTI is offline   Reply With Quote
Old 12-19-2017, 04:12 PM   #16
034Motorsport
Senior Member
The Dynamic+ Camber Mounts have a clear anodized finish, and it will not cause any issues mounting to the factory strut tower.
The additional camber is perfect for street use as well. My GTI sees many more commuting miles than track miles - it almost always gets driven to shows/events with equipment/products in the back - and there isn't a significant impact on tire wear with about -2.6 of camber up front. In general, more camber will increase inside tire wear, but the rate at which that happens depends on overall alignment (toe settings can have a major impact) and driving style. For example, without these mounts, these cars often see extremely excessive outside tire wear up front when pushed on track.
Yes, they've been in development/testing for quite some time now. I've had them on my GTI for almost 6 month now, and other 034Motorsport vehicles have had them on longer than that. There is a very minimal impact on noise, vibration, and harshness transfer into the cabin, especially when compared to spherical camber plates. If you have springs that are prone to binding, or very noisy tires, then those sounds may be amplified. On my GTI, I'm currently running these with our Dynamic+ Lowering Springs, and I honestly don't notice any additional noise with either of the wheel/tire setups I run.
Yes, these use the factory strut mount bearing, and have the necessary locating groove on them for ease of installation.
Hope that helps!
__________________
Old 12-19-2017, 04:34 PM   #17
THEREALVRT
Senior Member
Drives: MK7 GTI
nice pic
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
