FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Technical Topics > Golf Engine / Drivetrain / Exhaust / Tunes
Reply
Thread Tools Display Modes
Old 09-12-2017, 06:37 PM   #919
MeltedSolid
Senior Member
MeltedSolid's Avatar
Drives: Mk7 Golf TSI Launch Edition
Quote:
Originally Posted by 17S View Post
I had a tank of 89 with about 3 gallons of 93 added half way through. I ran map zero until that was way down in the red and then bought 7 or 8 gallons of Sunoco 93. I ran some map 1 and 2 on this then went to map 6. I wish there was a simple way to verify that you are getting what you are paying for when buying 93.
Hm, in that case it must have been a fluke. There is no reason you should have correction with that modest of boost settings and 93 octane fuel. Try doing another log when you can.
__________________
2015 TSI Launch Edition | Deep Black | 5-spd manual | APR Stage 1 + JB4 + IS20 swap | DIY Turbo Muffler Delete | 17" Enkei RPF1's | 034 dogbone insert V1 | BC Racing BR series Coilovers | ST 25mm rear sway bar | DIY HD Clutch Stop | NGK RS7 Spark Plugs | VWR Catted Downpipe
MeltedSolid is offline   Reply With Quote
Old 09-12-2017, 07:02 PM   #920
17S
Junior Member
Drives: 2017 Golf S
Quote:
Originally Posted by TwinDad View Post
Here is an old log I found of 93 octane on the stock downpipe. I think the only thing different I eventually did was started to raid the boost level up in the lower rpms. Like start more at 2,500. Peak at 4,000 and then start to taper from there
http://www.datazap.me/u/jcranwell/18...-6-11-18-25-26
What was your FOL setting for this?
__________________
2017 Golf S 5MT 5 door. BMS turbo muffler delete, JB4, 034 Dogbone insert v2, Boomba DV spacer
17S is offline   Reply With Quote
Old 09-12-2017, 07:31 PM   #921
17S
Junior Member
Drives: 2017 Golf S
@meltedsolid et al
I will definitely post more logs. I appreciate you all taking the time to look at them!
__________________
Old 09-12-2017, 08:31 PM   #922
ChrisTsi
Senior Member
Drives: Golf 2016 1.8 TSI
Im running 94 octane in ontario , these are my settings.
1500 12
2000 13
2500 14
3000 15
3500 16
4000 18
4500 18
5000 18
5500 18
6000 15
6500 14
7000 13.5
__________________
My build thread: http://www.golfmk7.com/forums/showthread.php?t=35591
Instagram: Golf7Tsi
ChrisTsi is offline   Reply With Quote
Old 09-12-2017, 09:08 PM   #923
TwinDad
Senior Member
Drives: 2016 sportwagen
It was probably just 60. This was very early stages before we knew what we know today.
__________________
2016 GSW- JB4-IS20-e30-RS7 plugs-Piggie pipe-K&N drop in
TwinDad is offline   Reply With Quote
Old 09-12-2017, 09:08 PM   #924
TwinDad
Senior Member
Quote:
1500 12
2000 13
2500 14
3000 15
3500 16
4000 18
4500 18
5000 18
5500 18
6000 15
6500 14
7000 13.5
How do the logs look?
__________________
Old 09-12-2017, 09:13 PM   #925
ChrisTsi
Senior Member
ill post a log tonight, i was at 16 PSI previously along that RPM bang 3500-5500 i can't remember and george said logs looked good and that was at 91 octane.
__________________
Instagram: Golf7Tsi
Old 09-12-2017, 09:35 PM   #926
TwinDad
Senior Member
Just watch the ign.1.
__________________
Old 09-12-2017, 09:45 PM   #927
ChrisTsi
Senior Member
what should ign1 be at or under or over
__________________
Instagram: Golf7Tsi
Old 09-13-2017, 12:41 AM   #928
TwinDad
Senior Member
Run a map 4 log as a baseline. Then compare the ign1 numbers to your map 6. Wherever it lower by 2 or more than it was on map 4, you need to lower the boost some. Chances are that without a downpipe, those settings are too high
__________________
Old 09-13-2017, 03:38 AM   #929
17S
Junior Member
Drives: 2017 Golf S
What do we know today? Does higher FOL make the mix more rich? Lower trims?
__________________
Old 09-13-2017, 12:04 PM   #930
TwinDad
Senior Member
A lot of the original info for the JB4 was based on what works for the 2.0 engines. The 1.8 works differently. The gti sometimes has issues at FOL 60 and they have to lower it a little bit. With us, we have gone as high as 75 with positive results. The higher the FOL, the more fuel rail pressure. Most tunes are fine at 60. If you start blending in e85, add a downpipe and start pushing the. Post higher, your trims will get too high and the AFR will lean out. Then you will need to increase the FOL. I think Ton tried FOL 80, but he got a CEL. I'm at 75 when I run some e85 and Ironshade is at 75 with the IS20 and some e85.
__________________
Old 09-13-2017, 03:50 PM   #931
Gawernator
Senior Member
Gawernator's Avatar
Drives: '17 Wolfsburg 1.8T; '15 ZX6R Racebike (x2)
FOL?
__________________
Watchdog Armory Racing AFM #725 Thanks to my 2018 Sponsors:
JPH Suspension | AXO Racing | Armour Bodies | BELL Helmets | EVLUTION Nutrition | Forcefield Armor | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Gawernator is offline   Reply With Quote
Old 09-13-2017, 05:24 PM   #932
TwinDad
Senior Member
Quote:
Originally Posted by Gawernator View Post
FOL?
Fuel open loop. With a flash tune, they change the injector cycle to add the additional fuel needed for the increased boost. Since the JB4 is tricking the ECU, upping the FOL adds more fuel rail pressure to get the additional fuel needed. When you stack the JB4 on a flash, the FOL is usually only set to 10
__________________
Old 09-13-2017, 05:39 PM   #933
stuntnuts
Senior Member
Drives: 2016 GSW
The more I hear about "FOL" the more I feel like it's a farce. Could someone please (preferably George) explain exactly how the JB4 unit "adjusts fuel rail pressure" via only connecting to an RPM sensor and a couple of boost sensors? How is it telling the ECU to do this?
BTW, I'm not anti-JB4. I have one sitting on my shelf waiting to install with my IS20 upgrade.
stuntnuts is offline   Reply With Quote
Old 09-13-2017, 05:46 PM   #934
Diggs24
Senior Member
Diggs24's Avatar
Drives: 2015 GTI; 2003 Saab 9-3 SS
Did you forget the CANbus connection?
__________________
JB4 / IE Intercooler / MAP cat+res Downpipe
Diggs24 is offline   Reply With Quote
Old 09-13-2017, 05:56 PM   #935
Gawernator
Senior Member
Gawernator's Avatar
Thanks.
Me too. I feel like I'm going to have to wait for the end of the racing season before I can install the JB4 and turbo
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
