FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Technical Topics > Exterior / Interior Care (washing, detailing, exterior repairs)
Reply
Thread Tools Display Modes
Old 09-12-2016, 02:49 PM   #35
cldlhd
Senior Member
Drives: 2005 infiniti g35 coupe 6spd manual,2016 Golf SE
Quote:
Originally Posted by Diggs24 View Post
Ditto. A how to would be awesome. TIA.
Hey is your avatar that crazy ancient aliens guy?
cldlhd is offline   Reply With Quote
Old 09-12-2016, 02:51 PM   #36
GolfWang
Senior Member
GolfWang's Avatar
Drives: '15 Night Blue DSG S
Quote:
Yes
GolfWang is offline   Reply With Quote
Old 09-12-2016, 07:34 PM   #37
danielmckendry
Senior Member
danielmckendry's Avatar
Sorry lads, this isn't going to be detailed at all, i didn't want to use the trim tools to take the trim off incase i damaged the plastidip but hopefully this gives you a good idea.
This is the centre trim as it should be:
1rst - air con trim: Take off the trim from around the air con controls - very easy, just open the drawer below, get a good grip on the trim piece, i usually put my hand in the middle and pull it out towards yourself, all the trim pieces are held in place by compression clips.
2nd - infotainment & top vent trim: Now that the aircon trim is gone, you can do the same again with this, just get a good grip in the centre and pull towards yourself, this will unclip until about half way up.
3rd: This is when you need the trim tools, you need a tool that will go behind the trim at the very top, above the vents, you need to get the tool in there and work the trim out, work around the outside edges all around the top half of the trim just slowly trying to lever it out, the vent shutters should stay in place.
4th: Then you take off the drivers vent trim, again working around the edges trying to lever it out, the vent shutters can come out too, but don't worry, theyvaren't connected to anythin, they're just shutters.
5th: The little piece above the steering wheel, you just pull it out towards yourself:
6th: After you've done all of the above, all you'll be left with is the gauge trim, again you just need to work the trim tool around the edges.
Don't be afraid to give it some force, i was crapping myself when i first did it, but they are stronger than they look. The trim is well held in by compression clips.
I hope this can help yous out a bit, like i say i didn't want to use the trim tools because it will tear my plastidip. But if anybody needs any more help i'll see what i can do. Couldn't do a video, i'm on my own and my phone battery was just about dead.
I'm a wizard with photoshop, so if you think you need more detail and arrows etc would help, i'm sure i'll be able to put something together in time.
Sent from my GT-I9300 using Tapatalk
danielmckendry is offline   Reply With Quote
Old 09-12-2016, 07:42 PM   #38
cldlhd
Senior Member
Thanks a lot, definitely appreciated.
Old 09-13-2016, 02:47 AM   #39
Senior Member
Sandman GTI's Avatar
Drives: GTI MK7 Autobahn, PP, DCC+LP, 97 F-150 4.6L V8
Thanks. Will give it a go.
Looks like you did a good job on the white interior.
__________________
Sandman
My Build Thread: http://www.golfmk7.com/forums/showthread.php?t=6100
Sandman GTI is offline   Reply With Quote
Old 09-13-2016, 10:03 PM   #40
danielmckendry
Senior Member
Cheers, problem with plastidip is that it attracts dust like flies to crap and when it's white like mine i notice it. It was white carbon wrap before, similar problem but the dip is easier to clean or patch up if i ever need to
Old 09-13-2016, 10:07 PM   #41
danielmckendry
Senior Member
If you take the trim off and go in with the mindset that if you do somehow break something, theres plenty of spares on eBay that you can replace them with. That way you might not be so delicate. The first time i did it, i got fed up trying to be delicate and just thought fk it, and it worked, no damage.
Old 09-23-2016, 08:08 PM   #42
euroadb
Senior Member
euroadb's Avatar
Drives: 2016 GTI SE w/ PP LP 6MT Pure White
Has anyone used Novus, and then subsequently used Quixx with better results? I just tried to use Novus 2 on an inconspicuous area and all it did was create even more micro scratches which further pisses me off. These plastics should be coated with gorilla glass FFS. It's ridiculous to think a quick clean caused so many scratches on my gauge cluster.
Anyway, I might just go the route with the protection film and call it a day. It never even occurred to me that someone would manufacture a protection film for this stuff. At least that will actually hide the scratches and protect it further instead of me dealing with crappy scratch removers and gunking up my gauges.
Quote:
Originally Posted by DCCSGMK7 View Post
http://www.aliexpress.com/item/Free-...08.0.65.l4goQ1
I have light swirls on my gauges which i covered up using using film from Aliexpress. Not a 100% but at least it'll prevent new scratches. I only bought one set because it was my first time ordering from there and I wish I bought more. It's a little tricky applying the film because of the tight space and curvature of the gauges so it's nice to have extras just in case.
How does it look with the film? Does it look 100% oem brand new and shiny? Or does it have an odd noticeable texture? How was it applying the film? Seems like it would be a huge PITA getting it on there without dust or air bubbles, considering how even a phone is a pain.
euroadb is offline   Reply With Quote
Old 09-25-2016, 06:15 PM   #43
DCCSGMK7
Junior Member
Drives: 2016 PP GTI
I'm on my iPad so hopefully the images attached correctly. Don't mind the dust...it's been a while since I cleaned my car . I did a quick wipe down which pushed the dust down to the bottom edge of the film, so the edge looks more noticeable in the pics. I was pretty rough with the wiping too and no scratches appeared on the film as far as I can see. I don't notice the edges when driving, but I guess it depends how OCD you are.
Dust wasn't much of an issue during application as the kit comes with a light piece of tape to remove dust. Aligning without air bubbles was a bit of a PITA though. I had to pull the film back up a few times to realign or remove stubborn air bubbles. I'm not a pro at applying film since I never use it on my phones so YMMV.
DCCSGMK7 is offline   Reply With Quote
Old 08-13-2017, 10:41 PM   #44
H15A
Junior Member
Drives: MK7 GTI SE
Quote:
Originally Posted by gx33 View Post
(sorry if this is double posted, please delete the other post)
I was able to try out a product (Quixx Acrylic Scratch Remover) on my lunch break today that another forum member suggested (sorry no shout out, can't find the OP).
The problem: I had two scratches. The first was a 4inch scratch on the gauge cluster that looked like a hair (thin, very visible). The second was a 1/8in scuff on the passenger side faux carbon door trim.
I am kicking myself for not taking "before" pics, but I was able to find a picture of the gauge cluster that you can *barely* see the scratch in:
So I followed the instructions on the back of the product for removing "light scratches". Both scratches were completely removed. No hazing or fading was left behind on either surface (I was worried about the door trim).
Hope this helps somebody!
I tried removing the scratches using Meguairs PlastX and it just put a bunch of small scratches in there to replace the scratches I was trying to remove. Im going to give Quixx a try.
Can you detail exactly what applicator pad and microfiber towel you used to clean it? It seems like no matter what softness, anything scratches it up again.
H15A is offline   Reply With Quote
Old 09-09-2017, 11:16 PM   #45
H15A
Junior Member
Drives: MK7 GTI SE
So I ordered the Quixx Acrylic Scratch Remover from ebay (the only way to get that bottle in the USA). I tried it out with the included cotton towel and it did nothing to correct the fine scratches. When the sun hits the cluster, its literally scratch mania. Looks hazy too. What are you guys doing different to get your results? Please share! Thanks!
Old 09-13-2017, 02:08 AM   #46
danielmckendry
Senior Member
Quote:
Worked a treat for me, and my cluster is still clear after many many months since it was done. I followed the instructions on the box. You wipe a little bit on and buff it off, just a little bit.
Sent from my SM-G950F using Tapatalk
Old 09-22-2017, 09:57 PM   #47
TheJokker
Senior Member
TheJokker's Avatar
Drives: 2016 2-door gti S, MT, PP
Quote:
Originally Posted by The Fed View Post
I use toothpaste.
Actually he is correct. Toothpaste is a (very) mildly abrasive polish. I'm an IT professional and as a tech I have been fixing scratched installation CD's for years with toothpaste.
TheJokker is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
