FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Regional Forums > NY / NJ / CT / PA
Reply
Thread Tools Display Modes
Old 03-02-2015, 06:16 PM   #1
vwgti2.0t
Junior Member
Drives: GT30 MK6 GTI
Cheap Labor: Pittsburgh Area
Hey fellas. I'm new on the MK7 forum, but am very active over on the MK6 forum. I figured I would post this in here as well.
I've been working on cars my entire life, I worked at my parents garage all through High School/College. I'm a Mechanical Engineer by day, and am usually caught up in some sort of car/bike modifying in my free time. I've done installs on anything and everything you can imagine, and have helped out more MK6 members than I can count installing parts for a fraction of the cost that you would pay at a specialty shop or dealer.
You can find my great feedback over on my golfmk6 thread here:
http://www.golfmk6.com/forums/showthread.php?t=74983
This is a ballpark estimate guide from my thread over on golfmk6. Granted some of these may not directly translate to things you can do on the new MK7 GTI, I can assure you I am more than capable of installing any parts you need fitted. I also own a mig welder for custom projects, along with most specialty VW tools needed for some repairs.
Quote:
So these are ballpark estimates, but:
Carbon Cleaning: $300 + 4 injector kits + Cleaner
Upgraded Turbo Install: $325
Coilover/Spring install: $225 (If doing coilovers, I would suggest also replacing the strut mounts)
DSG Flush: $150 + Materials (fluid/filter/o-ring/gasket)
Subwoofer Install (Amp Power/Ground/Signal, Tapping into speakers for line level inputs): $200 + Wiring Kit + Line Level Converter (if your amp doesn't have them) + Amp/Sub/Box. All ran neatly through OEM Wiring trays.
Door Speaker Install: $100 If going with components, it will be an extra $30 to mount them into the OEM tweeter locations.
Downpipe Install: $150
*If you are buying a raceland/godspeed/ebay downpipe, buy a REAL V-Band clamp, the ones they come with are junk and break almost immediately.
**If you need an extra O2 bung installed for whatever reason, I can do this for an extra 30 bucks + the bung will be provided by you
Catback Install: $150
Diverter Valve/DV+ Install: $40
Short Shifter Install:
$30 for just the weight and cable adjustments
$60 for Diesel Geek OR Weight plus side to side shortening, plus readjusting cables.
Boost Gauge Install: $100 + Wire Taps
WALK Install: $100 for Whiteline Kit, $125 for Superpro
Rear Swaybar Install: $75
Intercooler Install: $175
Turbo Outlet Pipe Install: $50
Throttle Body Pipe Install: $50
BOTH ABOVE for $75
Intake Install: $50 (I'm assuming most people can do this themselves, but I'll just throw it out there anyway)
Subframe Mount Install: $50 for HPA or insert. I really want to stay away from the VWR or 034 ones at this point as it involves dropping the subframe, and I just don't have the extra hands or space (no lift) to do it.
Engine + Passenger Side Mount Install: $125
Brake Pads: $125*
Brake Pads + Rotors: $175*
Brake Lines + Pads: $160 + Fluid*
*ALL BRAKE JOBS WILL REQUIRE YOU TO BED THE PADS/ROTORS YOURSELF. I'M NOT GOING TO GO BEAT ON SOMEONE ELSES CAR TO COMPLETE THIS!
I also do detailing. AKA: Wash/wax/clay. These prices depend on what is being done. For a generic wash and wax using duragloss 2 part sealant it is $100.
Any questions/concerns feel free to contact me through PM pr text. Also, be sure to read through my other thread for peace of mind on the quality work I do.
Also, you can take a look through my build thread here and see the work I have done on my personal car. http://www.golfmk6.com/forums/showthread.php?t=54182
My name is Nick, I'm located in Shadyside and that's where all of my work is done. If you have a question, my number is 570-778-1464. Once again, feel free to call/text me.
vwgti2.0t is offline   Reply With Quote
Old 05-15-2015, 03:31 PM   #2
vwgti2.0t
Junior Member
Bump, work has been pouring in so far this year. Come on over to get your goodies installed for the show season!
Old 05-29-2015, 02:57 PM   #3
vwgti2.0t
Junior Member
BUMP
Old 02-05-2016, 07:19 PM   #4
vwgti2.0t
Junior Member
Still available fellas! Starting to ramp work back up for spring, and would love to build some modding relationships with you MK7 guys!
Old 02-17-2016, 11:00 PM   #5
GolfWang
Senior Member
GolfWang's Avatar
Drives: '15 Night Blue DSG S
Damn. Wish you were philly not Pittsburgh haha that drive is just too much
GolfWang is offline   Reply With Quote
Old 03-22-2016, 06:00 PM   #6
vwgti2.0t
Junior Member
Bump. Work is starting to pour in. PM me for any needs in Pittsburgh!
Old 03-24-2016, 08:25 PM   #7
Norsk
Senior Member
Drives: '16 GTI SE PP
I will vouch for Nick, and he's a good guy who will help you with anything. He helped removing the delay value on the clutch block bleeder. It was done in less than 30 minutes.
Norsk is offline   Reply With Quote
Old 06-14-2016, 02:58 PM   #8
vwgti2.0t
Junior Member
Hey guys! Haven't been keeping super up to date with this, but thought I'd share two mk7's I've worked on recently.
First off, installed a Southbend Stage 2 Daily clutch with lightweight flywheel in this Eurodyne Stage 2 MK7.
And a Remus exhaust on another. This catback had perfect fitment and everything was of GREAT quality!
__________________
http://www.golfmk7.com/forums/showthread.php?t=8550
YOUR LOCAL PITTSBURGH MECHANIC^
Old 06-14-2016, 03:14 PM   #9
Norsk
Senior Member
Quote:
Originally Posted by vwgti2.0t View Post
What Ramp are you using?
Old 06-14-2016, 03:27 PM   #10
vwgti2.0t
Junior Member
Quote:
I believe they are just regular Rhino Ramps. Can't remember as I've had them for years. Really the only time I use them is for catback installs, as I use jackstands for everything else. Most cars I work on don't come close to being able to drive up forward on them either.
Old 06-26-2016, 08:30 PM   #11
ITGUY
Senior Member
Drives: 2016 GTI
Wow I wish you were more central PA lol.. I'm all the way out east...
ITGUY is offline   Reply With Quote
Old 06-29-2016, 01:42 PM   #12
AlexLynch
Member
AlexLynch's Avatar
Drives: '16 GTI 6MT
I highly recommend Nick for work you don't trust yourself to do. Unlike any dealership and most shops, you can actually trust him. He was more than happy to let me watch and explain exactly what he was doing. He will definitely take care of your car.
__________________
Eurodyne Stage 2 93HT / Bull-X DP with HJS Cat / VWR Cup Edition Intake / South Bend Clutch Stage 2 Daily / Denso IKH24 / GFB DV+ / S3 Short Shifter / 42DD Bushings / VWR Springs / Spaced Cadiz 18" / BFG Rival S / Ed's Headlights / Cherry Red LED Tail Lights
Follow me on Instagram
AlexLynch is offline   Reply With Quote
Old 03-20-2017, 05:07 PM   #13
vwgti2.0t
Junior Member
BUMP, still around. Been busting out work! Completed a MK6 timing tensioner update last weekend, along with an MQB S3 downpipe and intake. Not to mention an HS Tuning RSR install on a MK6 yesterday.
PM me or email samoleskiperformance@gmail.com for more info!
Old 04-13-2017, 01:32 PM   #14
vwgti2.0t
Junior Member
bump
__________________
Old 04-13-2017, 01:40 PM   #15
BlueHen
Senior Member
BlueHen's Avatar
Drives: '16 GTI S PP LP 6M 4dr NBM
What's the clutch install price for a SB kit?
__________________
2016 GTI S 6M PP LP - JB1, AWE DP+Touring, PSS 235s on RSe52s, euro R tails, Helix sound, 3M Crystalline, other isht
2015 Sportwagen TDI S DSG - Stock as a muh fuh
BlueHen is offline   Reply With Quote
Old 04-13-2017, 04:52 PM   #16
GolfWang
Senior Member
GolfWang's Avatar
Sent you an email from c******d**3 at gmail, lookin forward to gettin started on my MK7
Old 04-18-2017, 01:48 PM   #17
vwgti2.0t
Junior Member
Quote:
$500
Quote:
Reply coming your way!
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
