FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Technical Topics > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Reply
Thread Tools Display Modes
Old 09-12-2017, 09:47 AM   #1
daredeezy619
Junior Member
Drives: MK7 GTI
AC line condensation/wet?
Took a 4 hour trip to california and noticed this line was wet. Anyone know if this is normal?
Notice along line with black nozzle
daredeezy619 is offline   Reply With Quote
Old 09-12-2017, 02:32 PM   #2
russiankid
Senior Member
Drives: Das Auto
It is normal, that is the low pressure line which gets very cold so condensation forms.
russiankid is offline   Reply With Quote
Old 09-12-2017, 02:39 PM   #3
tknj99
Senior Member
Drives: 2017 MK7 SE 6MT
Its also the reason you can see water dripping or puddles under a car in the summer after it has come to a stop
__________________
PW | 3M CS Tint | JB4 | Clutch Stop | Clutch Bleeder Mod | Clutch Spring Removed | Snow Grate Removed | OBDeleven | ST Rear Sway Bar | Modified stock intake grill with AFE Drop-In
As I lay rubber down the street, I pray for traction I may keep, and if I do begin to slide, please dear God protect my ride! - Amen!!!!
tknj99 is offline   Reply With Quote
Old 09-12-2017, 07:36 PM   #4
daredeezy619
Junior Member
Drives: MK7 GTI
Quote:
Awesome thanks. 👍🏽
Old 10-15-2017, 02:46 PM   #5
seanmcd
Senior Member
Drives: 2016 GTI Autobahn
this cracks me up. I do remember the first time way back in the day I saw a puddle of water under the car and freaked out...
seanmcd is offline   Reply With Quote
Old 12-04-2017, 04:06 AM   #6
Shane_Anigans
Senior Member
Shane_Anigans's Avatar
Drives: 2017 GTI Sport DSG
Quote:
When I was a service advisor, I'd get at least one freaked-out customer calling me whenever it was hot out, panicked about some fluid they saw leaking from their car. Every. Single. Day.
__________________
2017 GTI Sport DSG - Tornado Red | Recovering Honda Owner | Professional Car Nerd
Shane_Anigans is offline   Reply With Quote
Old 12-05-2017, 12:23 AM   #7
The Fed
Senior Member
The Fed's Avatar
Drives: 2016 Golf R
Quote:
Now it's because their low coolant or tire pressure warning comes on at the first cold snap.
__________________
(Mostly) Posted by Josh/AWE. Flapper valves are open at idle, close after 1100 RPM during part throttle. Full throttle 1st-4th gear the valves open until throttle let off. 4th gear, 1500 RPM to full throttle closed, closed until 3500 RPM, then open until lift off throttle.
The Fed is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
